Here's an odd one - the vent leaves the oil-fired boiler, enters the concrete foundation wall and comes up next to the house. It then turns and enters the chimney. Aside from the condensation issues and the proximity to the wooden steps, is this allowed?
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 Last edited by bsmith; 3/11/07 at 1:51 PM.. |
It's also subject to damage at this point. "A man cannot be truly grateful and remain unhappy"
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
isn't that some sort of composite siding it is going through? Minimum of 6" to combustibles if it is. Nasty installation at best.
Should it not also be a "B" vent??
Chimney Pro is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey Bill,
I'm sure you guys have discovered that there is no limit to the crazy things you find in some homes! I agree with what Charley said. From what I can see in the picture, it should be functionally ok. However, I think we all agree that the design is poor. As evidenced by the rust stains at the base of the pipe, the exposure to the elements has already started to deteriorate the pipe. At the very least, a safe water deflection system should be installed to help keep the area dry. Best case scenario would be to have the homeowner consult a local chimney professional about retro-fitting the pipe installation correctly within the basement, as Charles had suggested. Jae, to answer your question, Type B gas vent is for venting listed natural gas or liquid propane Category I appliances. The appliances listed below typically, but not always, use Type B gas vent systems: • Furnaces • Water Heaters • Boilers • Room Heaters • Decorative Gas Appliances • Floor Furnaces • Unit Heaters Have a great day guys! -Tom Last edited by Chimney Pro; 3/13/07 at 1:51 PM.. Reason: corrected mis-spelling |
| Question about a gas fireplace vent | jvogan | Inspecting HVAC Systems | 10 | 3/20/07 8:46 PM |
| Question re combustion air connected to vent | jhawes | Canadian Inspectors | 11 | 12/4/06 9:24 PM |
| Plumbing vent Routing Question | kweiss | Plumbing Inspections | 7 | 11/1/06 9:57 PM |
