Old 9/21/07, 3:43 PM
Skip Erwin Skip Erwin is offline
Please Note: Skip Erwin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Vented Gas Logs
How can I tell if gaslogs are the vented or non-vented type by visually inspecting them? I'm talking about the situation where there are gaslogs in a firepalce. I like to recomend that a stop be placed on the damper handle to keep the damper open.
Old 9/21/07, 7:56 PM
Default Re: Vented Gas Logs
Vent free gas logs will be listed as such but if there is a damper, I'm going to recommend it be locked open or removed for safety regardless.
Larry Kage, CMI
231 929 3525
Old 9/21/07, 8:01 PM
Originally Posted by lkage
Vent free gas logs
Larry;
Vent free gas logs!!!
Do they make such a thing? Never saw one.
Curious
I always thought that anything that burns needs to be vented, unless of course it is the size of a candle. ha. ha.
I agree with you on the damper.
Old 9/21/07, 8:02 PM
Michael Larson's Avatar
Please explain Larry.
Old 9/21/07, 8:04 PM
Originally Posted by mcyr
Larry;
Curious
Same question I asked Larry Marcel. Please explain.
Old 9/21/07, 8:11 PM
Michael;
I think I beat you by about a minute to the punch. ha. ha.
9/21/07, 7:01 PM
Marcel
Old 9/21/07, 8:14 PM
There is no need to vent a vent free log or appliance if they are permitted by local jurisdiction and the manufacturer's instructions are followed.
Old 9/21/07, 8:21 PM
I agree with that also, but do they make such a thing?
Still waiting for Larry's explanation.
Marcel
Old 9/21/07, 8:25 PM
Marcel
Yes they do.
Old 9/21/07, 8:27 PM
Larry, is this what you are talking about?
I thought you were talking about imittation logs.
Where Can Unvented Gas Logs Be Installed?
Unvented gas logs can be housed in a masonry fireplace or in special fireboxes made to resemble a hearth.
If Your Gas Logs Create Moisture
Water is another byproduct of combustion. If you have vented gas logs, most of the moisture escapes out the vent, but when you use unvented gas logs the extra moisture enters your home. That can be a plus for many homes during dry winter months, but if your home is tightly insulated, or you have a humidifier, the excess moisture might show up as condensation on cold windows.
Gas Log Safety
  • Unvented gas logs generate a lot of heat. Keep combustibles away from the fireplace.
  • Always leave the fireplace doors open during use.
  • Only burn the gas logs for a few hours at a time. Never go to sleep and leave unvented gas logs burning.
  • Open a window slightly while the gas logs are burning, to let fresh air enter the room.
  • Bigger is not always better. For best air quality, the gas fireplace unit you install should be approved for the size of the room it will be used in.
  • Unvented gas logs are not legal in all areas, so check your local building codes before buying a gas appliance.
  • Always follow the manufacturer's instructions when using any type of fuel-burning appliance.
Marcel
Old 9/21/07, 8:30 PM
If there is a damper then they installed the logs in a fireplace that was designed for venting. Vent free gas logs need to have the air intake cleaned regularly to remain 99.9 % clean burning. Otherwise they should shut off automatically. But they are not designed with a damper. So, if the fireplace was modified to accept the vent free it doesn't need a damper...so I say remove it or lock it open as a precaution.
http://homebuying.about.com/cs/gaslo...tfree_logs.htm
Larry Kage, CMI
231 929 3525
Old 9/21/07, 8:33 PM
If there is a damper then they installed the logs in a fireplace that was designed for venting. Vent free gas logs need to have the air intake cleaned regularly to remain 99.9 % clean burning. Otherwise the should shut off automatically. But they are not designed with a damper. So, if the fireplace was modified to accept the vent free it doesn't need a damper...so I say remove it or lock it open.
Removing the damper or locking it open defeats the the redeeming quality of the vent free log which is it's near 100% efficiency.
Old 9/21/07, 8:38 PM
That may be true but I'm in the safety business first and then the client can decide if they prefer efficiency...I guess after having one and cats, I saw how quickly the air intake plugged up and my CO detector would go off until I cleaned it and I got gun shy.
PS: It worked great the first few months then not so good.
Larry Kage, CMI
231 929 3525
Old 9/21/07, 8:39 PM
Larry, you have me confused;
If I were to use vent free logs in my fireplace that I have now, which I am looking into to make happen, why would I remove my damper if it is vent free?
It gets cold in Maine, and if I am not using the fireplace, my heat would just escape up the chimney.
Would it not be better for me to stick to a vented gas insert?
Marcel
Old 9/21/07, 8:42 PM
I understabd what you're saying Marcel but after having one in my own house I was not impressed...maybe the newer designs are better.
Larry Kage, CMI
231 929 3525
Gas Logs........ pabernathy Inspecting HVAC Systems 11 12/25/06 8:58 PM
Ventless Fireplace mbrabender Interior Inspections 56 10/22/06 6:27 AM
Ventless Gas Logs Skip Erwin Inspecting HVAC Systems 5 7/7/06 2:33 PM
Gas logs dmacy Inspecting HVAC Systems 9 3/17/06 8:35 AM
