Old 1/23/07, 5:37 PM
brepanshek brepanshek is offline
Please Note: brepanshek is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default venting
Old 1/23/07, 5:39 PM
Default Re: venting
Sorry what you are looking at is a hot water heater vent that is 3" and runs 15' to the chimney flue. Doesn't this seem to long? No back drafting was evident at time of operation.
Old 1/23/07, 5:44 PM
Default Re: venting
also saw this. this is a 5" single wall smoke pipe to chimney flue, do you see the the screen on the tee portion of the pipe? This is a naturaql gas furnace and this seems to be acting like a damper to prevent negitive draft for combustion gases. I don't know what this is and if is proper?????
Old 1/23/07, 5:51 PM
John W. Springstead's Avatar
John W. Springstead John W. Springstead is offline
Default Re: venting
All looks questionable to me and would require further evaluation and necessary repairs/upgrades by quailified HVAC tech.
John Springstead
Home Inspections of USA
1752 N.E. Torch Lake Dr.
Central Lake, MI 49622
1-231-544-8016 office
1-231-544-6001 fax
www.homeinspectionsusa.us
Old 1/24/07, 3:39 AM
jclark1's Avatar
jclark1 jclark1 is offline
Please Note: jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: venting
If it is 15' long, it needs about 4" total horizontal rise, and the top of the chimney would have to be 20' above where the connector enters the chimney. Per NFPA 211. http://www.nfpa.org/freecodes/free_access_document.asp
Old 1/24/07, 7:46 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: venting
Attachment 8639
Is the natural gas draft induced or natural draft? Is their a draft diverter on the furnace? Yes then this tee needs to be removed. If no then screen needs to be removed as that is the draft diverter. Screening the diverter will cause the flames to lift off the burners and pilot assembly during high draft conditions.
Old 1/24/07, 12:39 PM
Default Re: venting
It is natural draft, and this pic shows it has a heatilator on the smoke pipe. What this is doing is taking the exshaust flue gas heat through a exchanger and a mini blower fan blows the warm air into the basement for additional heat. So way is that screen tee in last pic required if so??????
Old 1/24/07, 11:41 PM
Default Re: venting
That's a draft hood that the heatilator is attached to. No the draft hood tee is not needed and is actually double drafting the furnace and is most likely causing spillage at the furnace's draft hood at times. Write it up for an HVAC Compnay evaluation.
Old 1/25/07, 2:50 PM
Default Re: venting
Thanks
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 10:36 AM
Venting a bathroom in a highrise condo Mark Ellison Inspecting HVAC Systems 1 10/9/06 12:00 AM
mixed fuel venting? sfalvey Inspecting HVAC Systems 7 4/17/06 10:23 AM
Bad Dryer and Bath Fan Venting Jkrt00 Inspecting HVAC Systems 3 3/14/06 12:07 AM
For anyone who needs info on venting! pbolliger Inspecting HVAC Systems 8 2/18/06 9:58 PM
