Old 8/13/08, 9:32 PM
sfalvey sfalvey is offline
Default Is this venting necessary?
Todays inspection was on a 23 year old condo.
Both the gas hot water heater and boiler are in separate closets on the 2nd floor. Both closets have a short metal vent in the ceiling (assuming to let warm air out (to the attic)) and combustion air in from the attic.
Are these necessary? What are the draw backs and general comments.
It doesn't sit right with me, but I can't put my finger on it.
Also check out the flue pipe job.
venting-necessary-img_5594.jpg   venting-necessary-img_5597.jpg   venting-necessary-img_5604.jpg   venting-necessary-img_5615.jpg   venting-necessary-img_5622.jpg
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 8/13/08, 9:46 PM
Colin Cutler Colin Cutler is offline
Please Note: Colin Cutler is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Is this venting necessary?
Scott, my take on the vent pipes in the attic is, there's more free air available in the attic than in perhaps a closed closet. but the horizontal flue looks kinda long.
Old 8/13/08, 10:21 PM
Charley L. Bottger's Avatar
That is the way we draw combustion air from attic here in this state all the time almost on every one The short pipe is suppose to be into the closet at least 12 inches and the longer pipe is suppose to be 12 inches from the floor creates a natural circulation.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 8/14/08, 8:41 PM
lfoster's Avatar
lfoster lfoster is offline
On pic 5, what about the piping that doesn't reach the ceiling vent opening?
Old 8/14/08, 9:08 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Linda, that looks like an opitcal conclusion. I think there are two holes there with the one pipe (against the wall) extending toward the floor.
Old 8/14/08, 9:14 PM
William J. Decker's Avatar
Combustion air cannot be drawn from the attic. The attic is ventilated to allow air outflow. The attic is under negative pressure, therefore. Stack effect.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 8/14/08, 9:16 PM
That is correct.
Scott Falvey
Newbury, NH
NACHI#05051292
Old 8/14/08, 9:43 PM
Brian E. Kelly's Avatar
03 IRC allows attic combustion air. 1703.2
Old 8/15/08, 1:30 AM
David A. Andersen's Avatar
Attic air here too.
BPI# 5015804
Old 8/15/08, 8:20 AM
It is allowed around here, too, Will.
Larry Kage, CMI
231 929 3525
Old 8/15/08, 9:05 AM
What, Two million homes in Ok improperly vented for combustion air
NACHI Member
State License # 130
Old 8/15/08, 10:09 AM
msylvester's Avatar
msylvester msylvester is offline
Send a message via AIM to msylvester
It's OK here in Illinois as well.
Mark Sylvester
P.I. Home Inspection Services
www.pihomeinspection.com
mark@pihomeinspection.com
Old 8/15/08, 3:14 PM
Mark Chicago is not in Illinois right
</IMG>
NACHI Member
State License # 130
Old 8/15/08, 3:27 PM
msylvester's Avatar
nowhere near Illinois.
Mark Sylvester
Old 8/15/08, 6:23 PM
I stand corrected by my peers.
I was always taught that getting combustion air from the attic was wrong, mainly because of the stack effect and that the attic tends to craw air out.
Must have been wrong.
Sorry.
Will Decker, CMI
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Water Heater Venting dedwards Plumbing Inspections 1 8/19/06 12:46 PM
mixed fuel venting? sfalvey Inspecting HVAC Systems 7 4/17/06 9:23 AM
For anyone who needs info on venting! pbolliger Inspecting HVAC Systems 8 2/18/06 8:58 PM
