Old 2/2/06, 1:55 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Default Venting question
I've never seen a setup like this one -
The vent on the right is from hot water heater #1.
The middle vent is from the second floor gas fired boiler.
The left vent is from the first floor forced hot air furnace.
There is an additional hot water heater that joins the manifold just out of the picture.
If I'm not mistaken, smaller units should join the vent after/over the larger units. Does this look ok?
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Old 2/7/06, 3:39 PM
Brady Brady is offline
Please Note: Brady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Venting question
Not sure, but I think that if the vent stack is inclining, then it should be OK..
Old 2/8/06, 7:44 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Most manufacturers recommend a 10 - 12 inch vertical rise on the vent before elbowing the vent. Don't see that on the water heater. Write it up for the trades to check especially if you see evidence of spillage at the draft hood area.
Old 2/9/06, 10:13 PM
Robert Wade Robert Wade is offline
Please Note: Robert Wade is a non-member guest and is in no way affiliated with InterNACHI or its members.
Bill, AGA (American Gas Association) and GAMA (Gas Appliance Manufacturers Association) have publication called "Venting Tables Category 1 Central Furnaces" that might help you. It shows examples of multiple fan-assisted and natural vent combinations and the requirements for vent size and capacity.
Old 2/10/06, 12:41 AM
hspinnler's Avatar
hspinnler hspinnler is offline
Please Note: hspinnler is a non-member guest and is in no way affiliated with InterNACHI or its members.
I believe you are correct. The smaller appliances should connected to the highest available points above the larger appliance vents.
Old 2/13/06, 2:04 PM
Patrick Bolliger's Avatar
Unhappy Re: Venting question
AAAAAHHHHHH!
What a lousy potentially dangerous install!
My local gas company training tells me this:
These should all be cat 1 natural draft appliances... NO mixing of negative pressure and positive pressure should there be any!
Notice the draft hood on the water heater? Take a look at the slope of the flue after the hood! Wrong! Wrong location since it is smaller in diameter then the rest of the flues (Fau's) The smallest flue should be closer to the chimney then the larger one. So much more here.. The hood also looks as if there could be evidence of excessive rusting telling me that draft / draw is improper..
The slope period!!
The size of all these flues in that contraption of a connection! No "Y" gradual sizing connections just one big "manifold" deal...
Sizing issues with respect to all appliances working at the same time and one working by itself!!
GAMA or local gas company requirements ,check the installs regarding Chimney (perhaps no liner to) size and BTU's/ appliances per sizing.. Seven times rule and so on.. Even the Mfg. Installation instructions are # 1 to look at first then AHJ since the appliance Mfg.'s use GAMA guidelines for design..
Old 2/14/06, 7:14 AM
Bill Smith's Avatar
Excellent post - Thanks Patrick.
631-434-5200
Venting Materials question bmargiotti Inspecting HVAC Systems 4 11/15/07 5:08 AM
Venting Question dmacy Inspecting HVAC Systems 4 8/30/07 7:33 PM
Island sink venting question ehyde Plumbing Inspections 4 7/13/07 1:36 AM
Basement Bathroom Venting Question Sean M. Jeric Plumbing Inspections 4 3/20/07 11:56 PM
