Old 8/5/07, 9:03 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Default Venting Question
Could someone explain to me why the water heater flue needs to be above the larger furnace flue as illistrated.
If there is a refernce code that someone could provide?
Old 8/5/07, 10:51 PM
mdiplock's Avatar
mdiplock mdiplock is offline
Default Re: Venting Question
The reason for this is that if both appliances are firing at the same time the lager unit can choke off the exhaust of the smaller unit if the larger unit is on top. Thus causing backdrafting of the smaller unit.
a wise man once told me, "life is short, so learn from your mistakes, but more importantly learn from others mistakes as well because you don't have time to make them all yourself"
Regards,
Mark
Old 8/6/07, 11:37 PM
mthomas2 mthomas2 is offline
The way Douglas Hanson (CodeCheck) explains it, when a flue/vent is cold there is a column of cold air that must be heated and displaced before a good draft is established.
In a properly sized dual appliance vent, the vent
above the junction of the two appliances is larger than would be required for either appliance connected to the vent by itself, so the column of cold air is even larger than at a single appliance vent.
Thus, this smaller appliance, especially, needs to be in the most advantageous position to displace the cold air.
If the smaller vent is the higher connection, there is less cold air to displace.
Old 8/7/07, 2:08 PM
Patrick Bolliger's Avatar
Thumbs up Re: Venting Question
Hi all,
I think you will find this web site very useful on venting done right from the
Gas Appliance Mfg. association.
http://gamanet.org/gama/inforesource...y?OpenDocument
They have a really nice video explaining venting principals.
Old 8/30/07, 8:33 PM
Dang! I meant venting "Priniciples"....
Venting principals is illegal in this country...
Venting Materials question bmargiotti Inspecting HVAC Systems 4 11/15/07 6:08 AM
Island sink venting question ehyde Plumbing Inspections 4 7/13/07 2:36 AM
Basement Bathroom Venting Question Sean M. Jeric Plumbing Inspections 4 3/21/07 12:56 AM
Venting question bsmith Inspecting HVAC Systems 6 2/14/06 8:14 AM
