I thought I would share with you all, this is the third time I have seen this there are no vents in the crawl space just the vacuum under the house on the far East side next to the furnace, its termination point is next to the A/C unit (which is fine). However on the far East side there is some mold noted below 9 sqf. So does anyone out there no the benefits of this unit?
Does it cost lest to put this in versus pouring for the vents? Feed back would be great. Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
Is that being used for Radon mitigation?
No just to keep the air in the crawl (good) Radon is very low here my tests have shown less than 1.0 pcl
Let me just say if it is they dont know it.
http://www.humidexatlantic.com/conte...humidifier.cfm More later...got to go! |
Troy, I have also seen this type of unit used for clothes dryer venting on long runs.
I could see no other purpose. Did the pipe originate under a barrier or slab and exit the exterior or through the roof? old thread ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 1/29/08 at 7:30 PM.. |
They were called to fix the problems with the long (40-50' or so) dryer duct runs in a newer condo, charged the condo over $4,000 but their fix didn't work. I ended up recommending units like that (Fantech) controlled by pressure switches. |
The metal duct that moves the air is only about 2 feet long it comes up under garage floor area and terminates to the vacuum. The airflow terminated through the garage wall to the exterior near the a/c (its got good air you could probably blow dry your hair not mine)
I quit blow drying after this incident
ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 6/2/09 at 1:56 AM.. |
isn't it funny the things we do to pass the time.
we are so easily amused Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
How is the system controlled? Is there a dehumidistat as a main control or is it simply a switch? Or a 24 hour timer? |
Continual sucking was noted Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
No worries
| Return air from crawl space | WHI | Inspecting HVAC Systems | 11 | 1/9/12 8:43 PM |
| Crawl space in under house | dnasser | Structural Inspections | 15 | 2/27/07 8:12 PM |
| Ventless fireplace | jlybolt | Interior Inspections | 22 | 10/8/06 1:30 AM |
