Old 11/12/11, 10:37 AM
Greg Strump Greg Strump is offline
Default Verifying Capacity
I have a 10 year old Ruud air handler model #UBHB-24J11NFGA paired up with 4 year old Carrier condensing unit model #25HBR348A320. I was concerned that the air handler was only 2 tons while the condensing unit was 4 tons. To make matter worse the house is 2629 square feet. Should the air handler be replaced with a larger unit?
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/12/11, 1:51 PM
David A. Andersen's Avatar
Default Re: Verifying Capacity
Hell Yes!
You need twice the air flow for the new condenser!
BPI# 5015804
Old 11/12/11, 3:06 PM
Doug Edwards's Avatar
Curious what size Return Air grill? I find 3 ton and up units with a typical 12 X 24 RA.
- John Stuart Mill
Old 11/12/11, 5:03 PM
There were two returns in different rooms, they were around 16 x 16.
Old 11/12/11, 11:13 PM
Greg -
You don't have the knowledge or experience to make that call. MAYBE they changed the coils inside the case OR ......................
You do have the skill and knowledge to point out the POTENTIAL mismatch and recommend further evaluation by a licensed and competent HVAC contractor.
Old 11/13/11, 9:38 AM
Good point!
Old 11/13/11, 5:09 PM
Crap point.
It makes no never-mind if they changed coils, the AHU can not deliver the air required.
Yes you are qualified to make the call to the mfg with the equipment data and see what gives.
For what it is worth, those filters are too small for the 2 ton.
But I doubt they are 16 x 16.
BPI# 5015804
Old 11/13/11, 10:53 PM
Greg -
As person with degree in HVAC, past HVAC mfg rep, licensed HVAC contractor - I can't count the times somebody left an inside OR outside coil case intact - changed blowers, changed freon line size, changed coils, changed compressors, changed freons, etc ... My 1st post stands pat.
Then think about changes to the house / regardless of SF or filter size (which could be wrong). Orientation of house; insulation levels; the new argon gas windows; etc. WAY too many potentials to name.
Don't screw with it refer it to the people with the experience to properly handle it. Way too many arm chair designers on the web.
Water heater capacity lagudo Plumbing Inspections 9 4/4/08 10:23 AM
Need unit capacity info, please. lharrington Inspecting HVAC Systems 2 11/12/07 2:12 PM
Help on Capacity of Goodman jbarnett2 Inspecting HVAC Systems 4 2/14/07 11:30 PM
Service Capacity pdickerson Electrical Inspections 7 11/28/06 9:52 PM
