Albert Detorre is a non-member guest and is in no way affiliated with InterNACHI or its members.
My parents have been having a problem with their furnace. The furnace seems to run fine most of the time. However, on random occassions, the furnace begins to start up and get ready but it doesn't ignite and let out heat. So my parents flip the switch off and on to restart the furnace, then it ussually starts up and lets out the heat. This ussually happens at night at least two times a day.
They have called numerous HVAC experts and the gas company to look at the problem and no one has been able to fix it. All the repair people seem to be baffled. The electronic ignition, hot surface module, and thermostat have all been replaced. The gas company has checked to make sure there is no leak. The burners have also been cleaned to make sure no dirt is blocking the furnace from igniting. The model of the furnace is a ComfortMaker. It is about 20 years old. If you have any recommendations, please let me know. They are considering buying a new furnace and have spent 500 bucks so far in repairs. Thanks very much for your opinions! Al |
I recently had a similar problem with my Carrier furnace. It would go through the purge cycle and the hot surface igniter would glow. Then the gas would come on for about half a second before everything shut down. The problem was solved by replacing the thermostat. Apparently the defective thermostat was drawing too much current, so the control circuit became overloaded when the gas valve kicked in.
Jim King |
Any time a furnace cycles off on start up or shortly after you can bet your life that a operating or safety device is the reason someone just needs to have the knowledge to find which one is the guilty party. There are to many part changers in the HVAC field and not enough troubleshooters Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Well if it is 20 years old, $500.00 so far to fix, and if the other recomended fixes do not fix anything I would think about getting a new one at this point, why keep throwingmore $$ at it. Also see if the company that did the work will give you some kind of credit on a new system for consideration for the work done that didn't fix the problem.
Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
</IMG></IMG></IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
bbenjamin is a non-member guest and is in no way affiliated with InterNACHI or its members.
It sounds like from what I have read that your t-stat or your furnance could be wired incorrectly or your t-stat is not programed correctly for your furnace. Since the ignition has been changed that is ruled out, but I would start with the t-stat.
Don't pay if it's not fixed.
If there is too much voltage drop, an HVAC tech SHOULD have the tools and knowhow to determine this. As Charlie posted, your getting close to a good down payment for a new unit with that repair bill. |
| Fetch Report problem | mhazelwood | Miscellaneous Discussion for Inspectors | 7 | 11/12/07 11:12 AM |
| Problem with MIC | mhazelwood | Miscellaneous Discussion for Inspectors | 11 | 10/18/07 4:29 PM |
| Is MAC a problem | bemelander | General Inspection Discussion | 3 | 9/6/07 11:44 AM |
| Camera Problem | nwagner | Miscellaneous Discussion for Inspectors | 19 | 7/30/07 10:10 PM |
| Plumbing problem at home. | mnahrgang | Plumbing Inspections | 25 | 7/10/07 5:32 PM |
