Hey Guys-
Are these okay? I'm seeing more of them on newer construction. I thought flues were suppose to terminate above the roof line. What makes this different than running the water heater flue out the side of the house? Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Yes, it is okay if the manufacturer designed it to terminate out the side wall, it can terminate out the sidewall within those parameters. Some water heater vents are designed to terminat out the sidewall also. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Direct vents are less sensitive than B vents to down drafting and often take in outside air through the same opening in a concentric vent system.
| No Vent Propane Gas Fireplace | jevans | Interior Inspections | 44 | 2/4/11 8:26 PM |
| Fireplace Vent and Patio Cover Framing Clearance? | rwashington | Exterior Inspections | 6 | 6/10/08 9:54 PM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
