Old 10/8/10, 8:21 PM
mnahrgang's Avatar
Default Water Cooled AC?
This mornings inspection included this POS Painted over AC unit, and I could use a little help with.
1) Do you recognize (by the looks of it) who the manufacturer might have been (all painted over).
2) You will notice what appears to be either a copper gas, or water line running to it from the side of the house. All I ever see around here are air cooled central air conditioners. Can you please educate me a little as to what this is? Maybe that's just the condensate line? Usually they are right next to the larger insulated line?
BTW, Surprising enough it cooled the house great, and seemed to be working just fine.
Mark Nahrgang
www.HeyMark.info
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/8/10, 8:53 PM
Michael R. Boyett's Avatar
Default Re: Water Cooled AC?
That might be an old Arkla Servel natural gas absorption unit or something similar. The small line might be the gas supply. I'm reaching here and don't know for sure. Here's an example of one.
Old 10/8/10, 9:29 PM
Kenneth Dolin's Avatar
Kenneth Dolin Kenneth Dolin is offline
are you sure thats not the high pressure line? Whats the air handler look like?
Ken Dolin
Kenco Home Inspections
WWW.Kenco.org
State of Florida Licensed Home Inspector HI 59
Old 10/8/10, 9:49 PM
mnahrgang's Avatar
It probably is... I just got confused because normally those lines are right strapped together, and run together. That makes the most sense and is the most common in this area.
Mark Nahrgang
www.HeyMark.info
Old 10/10/10, 9:28 PM
Carlos R. Orellana Carlos R. Orellana is offline
I would think is the liquid line as well,Probablly A/C guy just did not run it next to suction line,. Fan at condenser unit appears to remove heat.
Carlos Orellana
Houston Texas
Old 10/10/10, 10:40 PM
Marcel Gratton's Avatar
It's not water cooled.
Water cooled AC's condenser would usually be inside next to the furnace and would not have a cooling fan/coil.
On The Level Inspection
Gatineau, Québec
Old 10/11/10, 6:39 AM
Wayne B. Wilson's Avatar
Just a air cooled unit.
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 10/11/10, 8:35 AM
Bruce A. King's Avatar
Looks like a Carrier unit. They had some paint issues in the late 90's and some have been painted.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 10/11/10, 10:25 AM
Charley L. Bottger's Avatar
That is just a standard split system the suction line dryer indicates to me that the unit or the compressor has been changed out in the past may have had a leak on one of the lines that was not repairable due to location and was re-routed
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 10/11/10, 11:07 AM
mnahrgang's Avatar
That's a good explanation...
Mark Nahrgang
www.HeyMark.info
Total galvanic reaction? jtribuzio Plumbing Inspections 19 4/3/10 2:18 AM
Water Pressure Problem dcossar Plumbing Inspections 19 11/21/09 8:47 PM
smelly well water afrost Ancillary Inspection Services & Additional Topics 26 11/21/07 7:30 PM
