View Poll Results: Water Damaged surfaces within the HVAC return - do you operate the equipment?
Yes, I operate the equipment 12 75.00%
No, I do not operate the equipment 4 25.00%
Voters: 16. You may not vote on this poll
Old 6/6/11, 10:58 PM
Tim Spargo's Avatar
Default Water Damaged surfaces within the HVAC return - do you test?
You've seen it dozens of times.. and if you are newer, you *will see it dozens of times*.
You arrive to your inspection.. depending on your order of things, you end up in the garage. You find a Platform for the Furnace/FAU and Water Heater, which has leaked, contaminating the Return Air Compartment.
You pull the air handler cover, remove the filter inspecting the surfaces contained within... you see moldy water damaged surfaces and many times they are still wet.
You can discern what you *think* it is.. but you're not sure.
Do you operate the HVAC equipment...? As this is a vacant home, you may be contaminating a system with "stuff". BUT, you have a job to do.. the client may be more interested in knowing that their Furnace and AC work, more than your indicating that you don't recommend running the equipment until the problem is taken care of and cleaned up.
But the question remains... you have a dirty/moldy/rotten platform that houses the return air compartment for the furnace... Do you operate the HVAC?
Tim Spargo
Spec Rite Inspections
661-317-5770
Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/6/11, 11:37 PM
Charley L. Bottger's Avatar
Default Re: Water Damaged surfaces within the HVAC return - do you test?
Originally Posted by tspargo View Post
For the sake of the poll, this is a Vacant, Foreclosed home.
Vacant foreclosed home do not have the water on no leaks
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 6/6/11, 11:43 PM
Tim Spargo's Avatar
I've edited it.. for the sake of discussion, it's just moldy and ugly..
Side stepper
Tim Spargo
661-317-5770
Old 6/7/11, 12:03 AM
clambert2 clambert2 is offline
Please Note: clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Do you think you are the only one who has activated the HVAC system since the problem has been there? Run it! Every house has mold in it if you test hard enoough? Why do you think is shows up on wet drywall after only24 hours? It is there just needed moisture and food.
Old 6/7/11, 12:44 AM
Tim Spargo's Avatar
I'm in line with your thinking... but this was brought up for the exact reason you mentioned.. the part where WHO/WHEN system was run last. Is someone "furthering" a problem or not.
Tim Spargo
661-317-5770
Old 6/7/11, 7:46 AM
It does not really matter to me if there is mold in the return it is already contaminated. If the home is to be properly re mediated the HVAC system will have to be re mediated including treatment of the A-coil its a mute point
NACHI Member
State License # 130
Old 6/7/11, 10:27 AM
Robert J. OConnor's Avatar
Sure ... and if it's direct vent run it with the blower door cover off ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
hydronic radiant floor heat on hot water tanks mnicholet Plumbing Inspections 7 4/14/10 5:48 PM
vent pipe in return dlee2 Inspecting HVAC Systems 2 2/18/10 12:51 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
