Old 3/25/10, 9:06 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Water heater flue
New HI furnace installed. Water heater connected to the old furnace flue. What are your thoughts about this connection? I know this has been discuss here before, just too lazy to look it up.
Thanks!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/25/10, 9:18 PM
James E. Braun, CMI's Avatar
Default Re: Water heater flue
It should draw okay. I really see no problem. Having a bigger than needed flue is not an issue.
Old 3/25/10, 9:21 PM
Thanks, James, it is MILLER time. It has been a long day.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 3/26/10, 11:18 AM
Greg Keene, CPI's Avatar
Greg Keene, CPI Greg Keene, CPI is offline
Actually, the larger flue from the furnace could affect the draw from the WH. Going from a 3" flue to a 6" flue can reduce the draw. when the furnace was installed it would help the DWH draw. The only way to tell is to check for spillage that doesn't stop within 60 seconds. BTW, I might be wrong, but this is what I learned trying to get my BPI cert. Any HVAC guys out there to correct one of us?
Greg Keene
Clear Choice Home Inspections
Evergreen, CO
303-674-3234
greg@clearchoice-hi.com
Old 3/26/10, 11:27 AM
Bob Elliott's Avatar
Additional Guidelines for Single-Appliance
Vent Systems
The flow area of the vertical vent shall not exceed
seven times the flow area of the appliance flue collar
area or the draft hood outlet area. For instance, if:
The flue collar diameter is: 3" 4" 5" 6" 7" 8"
The maximum common
vent diameter allowed is: 8" 10" 12" 14" 18" 20"
Water heater flue vent taped lfoster Plumbing Inspections 6 4/27/08 8:49 AM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
