Old 12/13/10, 8:05 PM
Ron A. Bishop Ron A. Bishop is offline
Default water heater vent drafting issue
Any comments on this packaged HVAC unit being installed on top of this water heater gas vent?
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/13/10, 8:13 PM
Default Re: water heater vent drafting issue
Installation instructions prevail:
http://www.duravent.com/docs/instruct/L204A_apr00.pdf
Vent pipe with 3"-12" diameter
must terminate at least 2 feet higher than an adjacent wall or obstruction, if it
is within 8 feet. Vent pipe with 14" or larger diameter must terminate at least
2 feet higher than an adjacent wall or obstruction, if it is within 10 feet.
Larry Kage, CMI
231 929 3525
Old 12/14/10, 8:57 PM
jmoya jmoya is offline
No good!
Old 12/14/10, 9:42 PM
rsmith24 rsmith24 is offline
Yeah the flashing at the bottom is bent up and wind driven rain could get under it.
INSPECTIONLOGOS.COM
"I can keep explaining it for you, but I can't understand it for you".
Nick G.
Monroe Home Inspection
Old 12/14/10, 10:11 PM
James H. Bushart's Avatar
Did you do a spill test?
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Blackened area around water heater vent jfrederick Plumbing Inspections 6 9/29/10 11:59 PM
hydronic radiant floor heat on hot water tanks mnicholet Plumbing Inspections 7 4/14/10 5:48 PM
Site grading and drainage wdevries Canadian Inspectors 5 10/6/09 10:23 PM
