Metal ducting leads up to ...what looks like an older asbestos vent piping.
Should this be called out.....( that the asbestos vent pipe should removed ) and replaced with current duct materials? David
An Ounce of prevention is better than a pound of cure :} |
| Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It's probably Transite and looks in good condition. I would mention it's presence only, but would definately report on the improper mounting/brackets attempting to hold it in place. Is that twine???
"The vent includes a Transite pipe, which is comprised of a solid, cement-like material that is known to contain asbestos fibers. Admittedly, these fibers could not easily escape from within the material, but the majority of heat vents, and certainly those that pass through attics, are required to be double-walled, or Type-B. And, as an imperceptible crack in a single-walled vent pipe could result in a fire, we recommend that the Transite pipe be replaced with a modern double-walled type."
The underlined is an important comment with transite pipe. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Thanks Jeff.... An Ounce of prevention is better than a pound of cure :} |
Thanks Joe...Im going to save this info. An Ounce of prevention is better than a pound of cure :} |
Thanks larry....
And EPA says:
Thanks Michael....Im going to save all this info. An Ounce of prevention is better than a pound of cure :} |
The biggest concern (for me) is the potential for cracks that cannot be seen, but will allow heat to escape. For this reason, I always recommend replacement as a "recommended safety upgrade." IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks Jeff. I wasn't aware of the Transite classification being a "B-vent" (at the time).
Another concern, would be the exposure to elements above the roofline, but the OP didn't comment on that. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Something else to consider.
The ground doesn't shake so much in the midwest Jeff Pope. Do you know of cracks appearing in transite if it has not been subjected to mechanical impact? It was use around here sub slab heating duct but since it is considered non friable creating air born particles is difficult unless it is crushed. I make the client aware of the issue but do not recommend replaceent if it does not appear subject to mechnical damage. YMMV You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
That's true, and based on the damage caused in that Virgina tremor last week, it seems the rest of the country is a "third-world country" with regard to seismic requirements
I couldn't believe the extent of the damage caused by that little shaker. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
| Exterior tankless water heater vent clearance | jfrederick | Plumbing Inspections | 12 | 1/31/11 11:46 PM |
| Staining around water heater vent piping? | dnasser | Inspecting HVAC Systems | 5 | 11/3/09 3:36 PM |
| Tankless Water Heater Recall | ldapkus | Plumbing Inspections | 1 | 2/22/07 8:34 PM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
