Condensation drain line was attached to sewer drain pipe. Call it out because of gases seeping back into unit. The remodling contractor stated " a water trap is installed to prevent sewer gas from flowing back into unit" My question- Does this look like any type of water trap that would prevent gases from seeping back into unit? Also drain line was leaking from unit itself.
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
You are just so pickey!
Seriously
Seriously I am asking if we are seeing the whole thing or does the water flow uphill?
Need air gap and trap. Picture is blurry but what is that grey snake going to. |
Dont remember about grey snake but now i looked at it closer, looks like conduit; suppose to go back on re-inspection; the water flow is slightly downhill from unit to sewer line
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Not allowed to drill and tap into sewer lines like that. Improper
What is shown in pic 1 is not a trap but just an uphill section.
It would have been a lot easier to install a condensate pump and been done
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Its not acceptable to connect a condensate drain to a main waste line ... even with a trap in the condensate line. What happens in the fall/winter when the cooling system is not running and the condensate trap water dries out ...
. Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Exactly, thanks
| Condensation Drain line question | acassady | Inspecting HVAC Systems | 25 | 2/26/12 11:40 AM |
| PLEASE HELP! Need to change the SOPs, per NEMA | ktarasenko | Electrical Inspections | 76 | 4/19/10 8:15 PM |
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 294 | 2/10/08 1:20 AM |
