Lbisurfcaster is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does anyone have a age chart for Weil McClain Boilers. I was on the web site, but it doesn't look like they have anything posted.
Thanks, Chris |
jmichalski is a non-member guest and is in no way affiliated with InterNACHI or its members.
Chris,
There is no chart availabe. You have to call WEil McLain and give them the CP number (the numbers following the letters CP on the data plate). They will tell you the date it was shipped from the manufacturer and the destination. |
The information I have is thus:
There apparently are problems with the casting of the 232 series. The date is stamped on the name plate, but you can also use the serial number. Serial numbers come in two types: 65-0003 = 1965 5326736 = 1975 (October) 5366109 = 1976 5780174 = 1985 I don't really understand how the second set works. However, the information I have indicates that the second set of numbers runs sequentially, with about 40,000 units per year being made. So apparently the company started making the units in October 1975. So add 40,000 to 5326736 and those are the units made in October 1975 to September 1976. Etc. A lot of give and take, but you'll get close to the year anyway. Weil-McClain apparently was purchased by/merged with Marley but I don't know the date. Marley uses the two digits at the end of the serial number to indicate year, based on their fiscal year, June to May. So 53180/76 is from their fiscal year 1976. |
| Boiler Shutdown | dkoniuk | Inspecting HVAC Systems | 2 | 8/6/07 9:34 AM |
| Boiler Control Recall | ldapkus | Inspecting HVAC Systems | 0 | 1/25/07 4:50 PM |
| Peerless gas boiler | 53bako | Plumbing Inspections | 6 | 11/29/06 6:50 AM |
| Boiler question | dmacy | Inspecting HVAC Systems | 15 | 2/22/06 10:56 PM |
| Romex on a Boiler? | mgifford | Electrical Inspections | 7 | 1/10/06 4:27 PM |
