Black rubber hose (corrugated) supposed to be attached to? High efficiency Carrier Weathermaker...
Peter Doane Realty Check Inspection Service NACHI ID# 05120681
Anyone?
Wheres Charley when you need him. Peter Doane Realty Check Inspection Service NACHI ID# 05120681
Sorry been doing my favorite Sh!! building walls and hanging doors.
That rubber hose has a plug in it right can not tell from the pic for sure but appears that the furnace could also be used as a horizontal and that hose may be for that position would have to see where it was attached. BTW I took another look at you pic does not appear that the combustion blower is even connected up the gas line is travling in front of the discharge knockout Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging Last edited by cbottger; 7/19/08 at 12:16 AM.. |
Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
They are both capped. I would hope it is being discharged out the other side of the induced blower assy.
As Charlie posted this stuff is to configure the unit in different ways. Nothing to be concerned about. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Thanks Charley and others.
The blower is hooked up to the left, I should have included a second picture for you to see the whole set up sorry. Peter Doane Realty Check Inspection Service NACHI ID# 05120681
Many furnaces have several drains that are for use depending on how the furnace is oriented. Since this one is plugged, and the furnace likely works, it's probably one that's for use when the furnace is oriented differently.
Peter, I notice a lack of a drip leg on the gas supply pipe, maybe not needed, Propane, perhaps?
