What do you see wrong in this pic????
Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging Last edited by cbottger; 5/13/08 at 11:21 PM.. |
Tab M. Wilcox is a non-member guest and is in no way affiliated with InterNACHI or its members.
Compression fitting on the refrigerant line ?
The cover is missing?
Other than what looks like a bunch of crap and debris in the condensate drain pan I must be missing it. Unfortunately that is all too common from people using cheap filters or no filters at all. Lots of old dirt and dust on the inside of cabinet too. Another indicator of cheap filters. Do you happen to have a photo of the under side of the A coil?
The flex line to the water heater appears to "be its own drip-leg"--it's hard to tell from the picture but the black line seems to be at the same level as the base of the heater, while the flex-line dips below it. There is no evidence of a drip-leg at this point and the flex line can become clogged with the debris that the drip-leg is intended to remove.
...I think... "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Is the air flowing down instead of up ?
Some people prefer the evap coil to be arranged in an 'A' for upflow, and a 'V' for downflow, but that's just a personal preference. Most manufacturers nowadays ship an A for use as either up or down flow.
The reason I pulled the front on the coil box was the blower motor was severely matted with lint and I was expecting to find the A-coil front loaded also but it was not bad. Divorced lady of 4 years had been living in this home and was not mechanically inclined no regular filter changes that was my red flag for checking the unit very closely. Watch out for those trick questions they will get you every time. If you don't see something wrong say so. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
| Another case of wrong | cbottger | Inspecting HVAC Systems | 23 | 6/21/07 7:05 PM |
| Grandpa, what is wrong with the patio? | mcyr | Exterior Inspections | 1 | 5/12/07 11:29 PM |
| Anything wrong with this? | jweinberg | Electrical Inspections | 11 | 11/7/06 11:22 PM |
| see anything wrong | jmaisano | Electrical Inspections | 16 | 10/31/06 6:23 PM |
| Anything Wrong Here? | scosta | Inspecting HVAC Systems | 12 | 6/29/06 10:06 AM |
