Old 3/14/07, 6:32 PM
tneumann's Avatar
tneumann tneumann is offline
Default White streak
What "could" this white streak be indicative of?
Thanks.
Old 3/14/07, 6:41 PM
Default Re: White streak
Is that single wall chimney pipe in an attic?
Larry Kage, CMI
231 929 3525
Old 3/14/07, 7:00 PM
tneumann's Avatar
B vent
Old 3/14/07, 7:04 PM
Well, we can start by eliminating orange paint...
or sky-blue pink paint...
but how about when we get to white paint...would that work?
Old 3/14/07, 7:13 PM
tneumann's Avatar
I wish it had been paint...but it didn't "appear" to be paint....
Besides..it is at a joint......leakage of exhaust gases resulting in a deposit of some sort?
Come on..this house had 242 pictures..help a fellow out! I'm tired already and I know my client probably isn't going to buy the doggone house anyway....
Old 3/14/07, 8:09 PM
Charley L. Bottger's Avatar
Tony that is created from moisture that is what shows up on galvanized pipe when exposed to moisture. There is some condensate leaking out of that joint. Nice Picture
</IMG>
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 3/14/07, 8:13 PM
tneumann's Avatar
Thanks CB.....
Condensation caused by? Throw me a bone..I'm at my wits end....I need to eat and sleep.
Old 3/14/07, 8:20 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
When the exhaust gases "condense" on the inside of the pipe it runs out and creates this "effloresence" type material when it drys. It is an indication of "issues" with combustion/exhaust of the appliance. Oversized/unlined chimneys will create lots of this stuff as will a vent blocked by bees-----lots of causes.
Old 3/14/07, 8:23 PM
tneumann's Avatar
That is what I suspected...the furnace is only 25 years old ....
Thanks CB.....
Tony; its from the temperature difference between the pipe and the temperature of the space that the pipe is traveling thru. If you could see the inside of the pipe it would be totally white. Gotta go someone is banging on my door wanting to see horses. Sorry Later
</IMG>
NACHI Member
State License # 130
Old 3/14/07, 8:37 PM
wforsyth's Avatar
wforsyth wforsyth is offline
Please Note: wforsyth is a non-member guest and is in no way affiliated with InterNACHI or its members.
Why would that happen in a double wall insulated B vent? That seems contrary to the purpose of the pipe.
Old 3/14/07, 8:43 PM
Matt Berman, CMI Matt Berman, CMI is offline
Wink Re: White streak
Tony,all good answers so far.I have seen this many times before, that screw by the moisture streak may not have penitrated the inner flue lining and just pushed it in leaving an air gap causing condensation in that one spot.Just my opinion, Matt
Old 3/14/07, 8:52 PM
wforsyth's Avatar
Thanks Matt for explaining that. I wouldn't have thought of the screw doing that. That's what we're here for though. To learn.
I keep trying to remember that it's only a stupid question if you don't ask it, but I keep getting chewed out for asking. But I'm plugging on anyway.
Old 3/14/07, 9:13 PM
cbuell's Avatar
Have we established that the pipe is "b-vent"? Looks more like single wall. Usually there is some sort of "crimping" marks at the ends of both pipes where they come together. Also the stuff will still leak out between the seams of b-vent, as can be seen in this picture.
Old 3/14/07, 9:28 PM
wforsyth's Avatar
Would explain why it's hot as well.
White Powder on Attic Trusses jcooper2 Ancillary Inspection Services & Additional Topics 22 1/5/07 5:22 AM
