Old 7/30/10, 10:39 PM
James H. Bushart's Avatar
Default Are Whole House Fans Dangerous?
Energy auditors write them up. Should home inspectors, too?
Consider the following:
1. Creating a negative pressure inside the house draws in outside moisture and pollutants. (Crawlspace environments are actually sucked into the living space).
2. Imagine a small fire starting in the home while the fan is on and the family is sleeping. Will the fan draw smoke past the smoke detection system too quickly to be detected while drawing more air for the flames?
3. Is the attic adequately vented ... not just for the excess moisture, but to expel 1200 to 2000 CFM?
4. When they are off, they represent a penetration in the thermal boundary of the home and contribute to air leakage.
Thoughts?
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/30/10, 11:36 PM
Bruce A. King's Avatar
Default Re: Are Whole House Fans Dangerous?
We should include something about them since most homeowners would not know.
http://www.wholehousefan.com/consumeralert.html
http://ezinearticles.com/?The-Five-B...Fan&id=3341470
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 7/31/10, 5:15 AM
Bob Elliott's Avatar
Too many variables.
No easy answer.
Old 7/31/10, 6:40 AM
Wayne B. Wilson's Avatar
I mention them, Due to the fact of sucking everything in through the home, Dangerous maybe , they could be wired with the smoke detectors to shut down during a fire.Also some of the fans weigh a lot in the event of a fire Firemen could be injuried not realizing they have them in older homes, there is really no benefit from them.
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 7/31/10, 7:07 AM
Michael Larson's Avatar
That depends how the are constructed.
I had one recently that had fully insulated hinged box cover over it in the attic that had to be opened using a cable in the laundry closet.
I explained the whole thing to my client.
Michael Larson
Hudson, WI
Old 7/31/10, 7:32 AM
That is the best way explaining it to the customer, Mention it on the report CYA.
Most people will not use them . Somewhat like a gas fireplace.
Wayne Wilson
865-256-1490
Old 7/31/10, 9:37 AM
So....this one had an air bypass running through the wall into attic by way of the laundry closet.
James H. Bushart
314-803-2167
Old 7/31/10, 10:02 AM
Joe Funderburk, CMI's Avatar
Maybe put a sign beside the switch that says "Open the windows, Stupid!" With the windows open, I sincerely doubt anything from the crawl space gets drawn into the home. That would defy logic.
Do you have any evidence to substantiate the claim that a WH fan will cause the smoke detectors to fail to detect a fire?
As everyone knows, most homes built back in that day had large gable vents.
That is true. I include a comment advising them to build a thermally insulated enclosure when the fan is not in use.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 7/31/10, 10:12 AM
The cable ran through a small tube.
Any air bypass was minimal.
Michael Larson
Hudson, WI
Old 7/31/10, 11:25 AM
David A. Andersen's Avatar
If not, the fan will overheat and shut down.
It doesn't draw it in and leave it there. It keeps on going right out the fan...
Smoke evacuation may save lives.
Yes they do, but mostly in the winter, not in the summer.
Cold air does not "rise". As you know; there must be a pressure differential across a building opening to leak.
They should be sealed and insulated during the off season.
Your point about the smoke detector exists in most houses, even without the fan installed.
BPI# 5015804
Old 7/31/10, 4:59 PM
It also would spread fire faster . Positive pressure has been used in fire fighting for years Yes it clears the smoke , but you better be ready to snuff the source.Most of the ones Have seen have no insulation cover for the winter.
I just do not see the advantage of sucking Pollen and spores into your house.
Wayne Wilson
865-256-1490
Old 7/31/10, 5:54 PM
Bert B. de Haan Bert B. de Haan is offline
You're right. Cold air doesn't rise. I'm not sure what your point is though. The warm house air will rise and go through the cracks into the attic.
I have never seen a whole house fan here. Maybe they are more common elsewhere.
Benchmark Home Inspection Services.
http://www.KitchenerWaterlooHomeInspector.ca Kitchener-Wateroo and Guelph area Home Inspection
Serving Kitchener-Waterloo, Guelph, Orangeville, Mount Forest and surrounding areas.
Old 7/31/10, 5:58 PM
You probably will never see one up then Ben Maybe in the big Smoke in TO
Wayne Wilson
865-256-1490
Old 7/31/10, 7:21 PM
ldapkus ldapkus is offline
I've seen the same set up and a thermal scan indicated minimal air loss under negative pressure.
Old 7/31/10, 8:20 PM
Thermal scans do not and can not measure amounts of air leakage.
Since air leakage accounts for 5% to 40% of space-conditioning loss and is usually found to be many small sources of leaks combining for the total AER, there is no such thing as an insignificant air leak. Sometimes, under certain conditions, air leaks can be seen by IR cameras....but they can never be measured by them.
James H. Bushart
314-803-2167
Moldy House Costs Builder $3 Million dplummer Ancillary Inspection Services & Additional Topics 5 9/25/11 5:51 PM
Insulating Your House from CMHC mkyriacou Canadian Inspectors 10 2/14/10 3:50 PM
Coming soon. Free, online, fireplace and chimney inspection course. gromicko General Inspection Discussion 15 12/14/09 4:19 PM
Renovating Your Basement for Livability mkyriacou Canadian Inspectors 0 10/22/09 11:45 AM
What's Inside A Chimney mcyr Inspecting HVAC Systems 14 9/17/08 6:11 PM
