joe levy is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am interested in installing a whole house humidifier, but I have 2 challenges.
1. The air handler in located in an unheated attic. I can install heat tape to keep the 1/4" water supply line from freezing, but I wonder how to keep any reservoir water from freezing. 2. I have no way of draining excess water. Can anyone recommend a unit, or a solution? |
Buy a console humidifier.
Best solution is to forget it.
Joe, Unless recommended by a doctor, or unless you've got a house full of antiques that you are concerned about drying out, a humidifier is not a good idea. Homes today are built tight. And a lot of effort is taken to improve indoor air quality. In my opinion, whole house humidifiers, are just big petri dishes that blow spoors throughout your house, and feed those with plenty of moisture. Whenever I see one installed, I recommend the client turn the water off to it, dry it out, and not use it. If you need one for a particular reason, then a smaller room sized unit like Mike recommended would be better. At least then it isn't running 24/7. JMHO. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Joe, If you use an in-house unit and want the whole house treated, place it near the return register. The moisture will be distributed throughout the house. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
They do not have a reservoir and are self cleaning by flushing a little extra water through during operation. Any humidifier with standing water can become a little cesspool, not to mention having to carry 24 gallons a day to a portable unit to match the capacity of an Aprilaire or General. A sharp contractor can usually figure out a way to get a drain down through from an attic. |
There is also steam units where you put the head in the duct work and main unit can hang from the wall
| Moldy House Costs Builder $3 Million | dplummer | Ancillary Inspection Services & Additional Topics | 5 | 9/25/11 5:51 PM |
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 6:11 PM |
| Foam Insulation ? | wrandolph | General Inspection Discussion | 13 | 11/18/07 8:30 PM |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 10:47 PM |
