They had the same company come out 3 times, and they said they could not find anything wrong. PAALEASE!
Recommend not using that company anymore. 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Hired the company three times and didn't find that? I am assuming they were HVACR technicians then. It's gonna take a whole lotta cans of ZIP Clean to fix that problem. LOL
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Throw some more in and it will be good to go Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Gerry,
They are trying to cool the house not grow potatos. 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
The last thing to come out of a service truck is the hose and coil cleaner!
No evaluation can be properly done, without first using the hose and coil cleaner. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hmmmmm. Obviously they not only don't know how to check static pressure to determine cfm air flow they can't use their manifold gauges and thermometers to diagnose either. Can only imagine what the secondary heat exchanger looks like if this is a 90 percent efficiency furnace and the evaporator coil. Oh that first photo is the evaporator coil.
I had one last week where the indoor coil was blocked, resulting in low back pressure. Sooooo, someone just charged things up till the back pressure came up to 70# psig.
When I checked the unit, the suction service valve leaked when I took off the gauges and liquid refrigerant came pouring out! This valve was about 8" from the compressor! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
