2386 sq. ft. home built in 2006 in Laveen AZ. Both units model number say that they are 2.5 tons. The units are 30% bigger than my 5 ton unit. I have never seen units so big that have so little cooling capacity. I would have thought that 6 tons would be required for that size house. I know determining the adequacy of the size is beyond the scope of a home inspection. They provided plenty of cool air. Am I missing something or are these units just larger because of the new R410A freon?
Loren Green Greens Home Design L.L.C. www.GreensHomeDesign.com www.MyPhoenixHomeInspector.com www.inspectorpages.com/lgreen |
| Find an InterNACHI certified New Jersey Home Inspector (and anywhere else in North America) |
I do not know why the units are so big.
The freon would not make the difference and the sizing of the unit is enough cooling. FYI: A rule of thumb on sizing is the thermostat in the house should lose about one degree when the A/C is running on the hottest day. |
Not many heat pumps around here, the only one I saw was similar size, only 1 needed for a similar sized house. |
Efficiency...two and half tons is still two and half tons which is the "capacity" of the units. Now, I hate the installation location (poor) from a techs stand point. Hard to work in the cramped space, piss poor air flow through the outdoor units and I would pay someone else to pull or replace that unit in the back. Was this a two story house?
Just for giggles: http://www.hvacfun.com/a-conquering-...ump-phobia.htm "War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill Last edited by dedwards; 9/12/09 at 1:24 PM.. |
Sometimes multiple units are used instead of one large unit because it is hard to push cold air up ductwork, and it is just more efficient. |
Here all the air handlers are installed in the attic and the registers are in the ceiling. It is easy to push cold air down. For the two months that the heat is needed it is a little bit inefficient to push the heat down. It is two story. One unit for each level. Loren Green Greens Home Design L.L.C. www.GreensHomeDesign.com www.MyPhoenixHomeInspector.com www.inspectorpages.com/lgreen |
Loren the newer higher SEER units are physically bigger than the older units of the same tonnage.
Doug, on the zero lot line homes here somtimes that is all you get for access or installation. Not ideal, but it is what it is............. |
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Agreed, a 23 seer unit is the size of a Pinto.
Interesting, I just had a new 13 SEER heat pump unit installed a couple months ago. It is noticeably smaller than my previous unit. Same size, same brand. But then we don't see many straight A/C units up here. Mostly heat pumps. And it is welcome today. 86 degrees and humid today.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
We consider 86 a cold snap.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
I have a 3 ton seer 14 and a 3.5 ton seer 14 , the 3 ton is physically larger that the 3.5 ton because the coils are doubled up in the 3.5 ton unit. These are 2001 model Bryant units but I would think other brands have the double coils too. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
True. A lot of the older units had all the components outside the coil in a separate compartment. Lrge cabinets with relatively small coils. Now most have all the components nested inside the taller coils, very little casing, mostly high efficiency coils. Last time I upgraded a half ton, the condenser unit got a smaller footprint but grew about a foot taller. Gerry, I know what you are talking about. I was at a condo the other day, every unit there was a different brand, sizes all over the scale and mixed components from inside and outside and none marked to identify which unit it belonged to. Naturally, the sh*ttiest one there is the one you have to inspect.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill Last edited by dedwards; 9/11/09 at 9:19 PM.. |
| Heat Pumps | Stan Johnson | Inspecting HVAC Systems | 15 | 1/11/09 9:20 PM |
| Heat Pumps | charper | Inspecting HVAC Systems | 15 | 12/9/08 4:10 PM |
| Radiant Heat Transfer | rmyers1 | Structural Inspections | 0 | 5/31/06 11:21 PM |
| Heat pumps in Florida | cobarr | Inspecting HVAC Systems | 7 | 4/17/06 10:58 AM |
