lagudo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi All,
Two new AC units installed. Wiring is not correct on left side unit or is it? This is the first time I have run across this. What wording should be used for this? I have tried looking in the IRC but cannot find the right code. Is it in the mechanical or in the electrical? I believe the answer lies in wiring methods but I can't locate it. Thanks in advance. |
Looks like they used a piece of an old extension cord to wire from the switch to the unit. I'll bet the wire is undersized for both units.
ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
The wire looks to be a #10 which is correct ....but it should of course be in a whip ,or,conduit.
Advise to have an electrician correct it as it is unprotected and sub-standard. |
Also it does not appear that there is proper clearance for those disconects.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
It doesn't look like conduit protected wiring to me.
I'd call it out for an Electrician's evaluation. |
Cheramie is correct. whip or liquidtite. As far as the clearance goes, it probably does not meet the NEC requirements but is way better than a lot of homesI see in this area. ************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
FYI, many AHJ are loose with the rule that allows romex to be used where not subject to physical damage, like in the photo it's surrounded by large pieces of equipment. The one thing that should not at all be in question, NM-B is not UV resistant, therefore not allowed for outside applications like this. Flag it for that, and defer to a qualified electrician.
imho, tom |
Perhaps somewhere, but I still see a lot of white romex and orange #12 or #14 extension cords around here. I only trust what is printed on the sheath.
The 240 volt wiring at the A/C unit was not properly protected or encased. We recommend having a competent HVAC contractor or licensed electrician review the HVAC system electrical components and then repair as needed.
| Top Ten Wiring Hazards Threaten Life and Property | jtedesco1 | Electrical Inspections | 3 | 9/2/08 5:15 PM |
| Top Ten Wiring Hazards | jtedesco1 | Electrical Inspections | 6 | 9/1/08 8:26 PM |
| Wiring For AC Units | rnewland | Inspecting HVAC Systems | 14 | 8/27/07 1:39 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
| K&T splice. | egarcia1 | Electrical Inspections | 13 | 2/3/07 6:36 AM |
