What is the frontal workspace requirement for the control side of a furnace? I tried a search of the threads but nothing came up. I thought it was 36". Am I being too picky?
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
I believe it is 30". According to my Code Check book. Those are about all I use.
Working space is to be 30" X 30" with a clear and unobstructed passageway at least 22" wide leading to the unit. I always write-up obstructions, especially if it is a gas line such as what is there. Makes a nice trip hazard and damaging the gas line of course would not be good. How close are the suction and liquid lines to the flue pipe?? Looks to close. Also the liquid line is directly in front of the units front panel. I would write that up also as it is not only an obstruction but can potentially lead to damage of the line. The flex gas gas line also appears to be obstructing the front panel removal as is the white cabling. They require re-routing away from the panel access. Are those approves mounts under the unit? I rarely see units in the attic that are not mounted via straps to the framing so would have to look at Carriers install instructions. Now what were you saying about being to picky? Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
SECTION M1305
- APPLIANCE ACCESS - - M1305.1 Appliance access for inspection service, repair and replacement.Appliances shall be accessible for inspection, service, repair and replacement without removing permanent construction, other appliances, or any other piping or ducts not connected to the appliance being inspected, serviced, repaired or replaced. A level working space at least 30 inches deep and 30 inches wide (762 mm by 762 mm) shall be provided in front of the control side to service an appliance. Installation of room heaters shall be permitted with at least an 18-inch (457 mm) working space. A platform shall not be required for room heaters. |
HMMMMMM code inspectors
rsummers is a non-member guest and is in no way affiliated with InterNACHI or its members.
You're allowed to use a 24" service platform in may area but need to have 30" of space in front of access doors. When you hand a unit in a trussed attic they also look past framing blocking sections of unit doors as long as you can get them off. I don't know how many times Ive had to deal with a truss in front of a blower wheel.
| Furnace Problem Comments Welcome | rfrost | Inspecting HVAC Systems | 24 | 10/21/07 7:26 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 3:56 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 9:17 PM |
| Mismatched dead front | ghawley | Electrical Inspections | 5 | 2/10/07 10:56 PM |
