Old 8/5/11, 11:31 AM
Gregory A. Liebig's Avatar
Gregory A. Liebig Gregory A. Liebig is offline
Default When would a vent be required in a bathroom?
A home was built in the 1930's. There is visual updates in a 1st floor half bath including newer glass block window (no vent), newer sink, toilet, floor tile, etc. There is no ventilation except the HVAC duct at the floor and the door. I don't know when the work was done, but it obviously is not original.
After looking at many other "improvements" throughout the home, I suspect the work may have been done by the owner and possibly without permits but there is no way to know for sure without calling the local building inspection department (outside SOP). Any ideas?
Greg Liebig, Owner
Sheboygan Wisconsin Home Inspector
4-Square Home Inspections, LLC
Where Knowledge will put your Mind at Ease ©
Sheboygan, WI 53081
(920) 451-4646
www.sheboyganhomeinspector.com
www.4squarehi.com
Like Us on Facebook
Follow Us on Linked-In
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/5/11, 11:35 AM
Michael Larson's Avatar
Default Re: When would a vent be required in a bathroom?
I don't involve myself with permit issues.
I point out unprofessional work however.
Michael Larson
Hudson, WI
Old 8/5/11, 11:45 AM
I don't either, and I have used the non-professional work in the past. Maybe something like, "Visual evidence of recent updates. No ventilation installed. This could be an indication of non-professional work. Recommend consulting with a licensed HVAC contractor to confirm the work performed meets professional standards". I would tend to flag this as a maintenance item and not a Defect. OR
[Exhaust - NONE - Defect]There is no means of ventilation present either through a window or mechanically ventilated fan. Repairs recommended by a licensed HVAC technician.
Greg Liebig, Owner
Sheboygan, WI 53081
(920) 451-4646
www.4squarehi.com
Like Us on Facebook
Old 8/5/11, 11:56 AM
You can undercut doors to provide adequate return air.
http://www.baihp.org/casestud/return_air/index.htm
Michael Larson
Hudson, WI
Old 8/5/11, 12:03 PM
Not concerned with return air. Concerned that there was no window opening or mechanical means of ventilation installed in the bathroom.
Every bathroom requires an openable window that provides at least 1.5 square ft of air flow area when open – 2006 IRC [303.3] OR mechanical type ventilation: 50 CFM intermittent or 20 CFM continuous operation – 2006 IRC [303.3X]
Greg Liebig, Owner
Sheboygan, WI 53081
(920) 451-4646
www.4squarehi.com
Like Us on Facebook
Old 8/5/11, 12:08 PM
I missed your point. Sorry. I thought you were talking about a heating vent.
No ventilation always get written up by me.
Recommend addition of a exhaust vent to remove moisture and objectionable odors from bathroom.
Michael Larson
Hudson, WI
Old 8/5/11, 12:32 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Don't forget that what you are talking about is minimum. 50 cfm is safe for operation during occupancy and as Michael said, the door should be cut to provide proper ventilation.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 8/5/11, 12:37 PM
The undercut door is for the HVAC not room ventilation.
I misread Greg's intent.
Michael Larson
Hudson, WI
Old 8/5/11, 1:03 PM
KEVIN WOOD's Avatar
What goes out must come in.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 8/5/11, 1:04 PM
Please read Kevin.
You're confused.
Michael Larson
Hudson, WI
Old 8/5/11, 1:25 PM
KEVIN WOOD's Avatar
Don't forget that what you are talking about is minimum. 50 cfm is safe for operation during occupancy and the door should be under cut to provide proper ventilation unless the area around the door is not well sealed.
Is that better Michael
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 8/5/11, 1:35 PM
James H. Bushart's Avatar
Any ideas?
With or without windows (since very few will shower on a cold February night with an open window in the same room), all bathrooms need a means to send the moisture that is generated within them to the outdoors. It doesn't matter what a code book says or when they were built. The lack of a vent is a material defect and should be addressed in an inspection report.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 8/5/11, 1:35 PM
NO
He is asking about the lack of ventilation for the bathroom, not the heat source.
I misread his intent at first too but I explained that already. Read son.
Michael Larson
Hudson, WI
Old 8/5/11, 1:51 PM
As soon as I leave the room...
That should clear it up.
Old 8/5/11, 2:09 PM
KEVIN WOOD's Avatar
No one is talking about supply heat. We are talking about moisture removal through ventilation.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
The Importance of Bathroom and Kitchen Fans mkyriacou Interior Inspections 35 6/4/10 5:27 PM
Bathroom vent piping to "Near Exterior"? swaskewicz Inspecting HVAC Systems 26 6/4/10 4:35 PM
Bathroom vent to Stack vent sfalvey Plumbing Inspections 7 8/15/07 9:59 PM
Soot around the bathroom vent lclark Exterior Inspections 7 3/6/06 8:13 AM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 3:38 AM
