| View Poll Results: Is a natural gas line is combustible? | |||
| Yes, it will blow the house to bits |
9 | 36.00% |
| No, it was designed by NASA and can't be burnt |
6 | 24.00% |
| Please define combustible |
10 | 40.00% |
| Voters: 25. You may not vote on this poll | |||
“The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 8/12/06 at 1:07 AM.. |
Yesterday inspection, gas fireplace flue not connected in attic.
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Put a light a match and you can not get it to burn. Is it proper for the gas line to be touching the chimney again no. Gas flue open in to attic . I would write it up as gas flue open into attic requires immediate repair by qualified person. I see 81 people have looked and said nothing. Roy Cooke Google search gives this answer. below . Combustible Definition
We have had a few homes around here explode because of a natural gas leak, and all it took was a spark. So is it combustible?
Even then it required ignition from some other place. They put an oder in the gas so people will smell it . Sounds like some one must have damaged the line some how. There is no way to protect our selves from idiots all the time Roy Cooke |
I said the gas line will not burn. No one else answered . 106 lookers What is your position ? Roy Cooke |
Good point Joe.
I doubt if anyone including HI's would or should say that a plastic covered gas line is ok touching a B-vent. Is it a major issue? No and it is an easy fix so it should be corrected. I found sheetrock and carpet that had been up against a B-vent for 6 years with absolutely no signs of heat damage. I still recommended it be corrected. The issue (code intent and manuf. liability shield) is really with a runaway device that gets stuck on and therefore heats up the B-vent beyond what it normally would ever be. Single walled pipe is a different subject and obviously much more of an issue. |
" Is it proper for the gas line to be touching the chimney again no. " Roy Cooke |
Assuming the line has no leaks I guess it will just burn the house down at a normal speed. At a certain temperature, the metal itself will burn and then the fuel inside the line, which you say is not combustible, will burn too. If there is a leak in the line near the point of the initial fire, then there will be an accelerated fire. It's all very technical. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Will the plastic cover burn I do not think it by itself would burn but if the house was on fire I would expect you ,I and every one else would be far away watching. Roy Cooke |
I also found an installation manual tucked up nice and tight next to a B-vent right at the furnace. Looked like it had been there for a few years.
Combustible paper. No major sign of heat damage. See my prev post for the reason. |
Roy, so the manufacturer's warning about maintaining certain clearances to combustible materials doesn't apply because plastic won't burn and natural gas is not combustible either. Hummmmmm.
" Would you say a natural Gas line is combustible" I stick with me original answer NO! With help of a hot fire and much oxygen you can make the carbon in the steel line burn but no way can you under normal conditions get it to burn. Roy Cooke sr |
| 1 condensate line...... | Scott Schultz | Inspecting HVAC Systems | 2 | 11/4/07 7:18 AM |
| Size of supply line | aobrien | Inspecting HVAC Systems | 7 | 1/2/07 1:40 PM |
| TSSA Gas natural draft boiler notice | rwand1 | Canadian Inspectors | 0 | 9/13/06 12:37 AM |
| Flexible Natural Gas line | thejnicki | Plumbing Inspections | 4 | 8/1/06 12:30 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 8:59 AM |
