| HVAC Topics include heating, venting, and air conditioning. |
This furnace flue vent was touching the return air duct would you write it up.
I have already written the report and am curious as to what others might have said in this situation. Freedom Express Inspections LLC CMOR Thermography Certified Level 11 #2097 freedomexpressinspections.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F Professional Home Inspector State License # 130 Reporting system by Home Inspector Pro Serving the State of Okla. Last edited by cbottger; 5/13/08 at 11:19 PM.. |
Hi Charley,
yes I would have written it up, my thoughts are firstly that there is a potential safety issue as the flu will vibrate against the return and eventualy this will hole the flu, secondly there has to be efficiency issues with flu heat warming up the return duct. Regards Gerry Virtue is more to be feared than vice, because its excesses are not subject to the regulation of conscience. Adam Smith (1723-1790) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106
Freedom Express Inspections LLC CMOR Thermography Certified Level 11 #2097 freedomexpressinspections.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F Professional Home Inspector State License # 130 Reporting system by Home Inspector Pro Serving the State of Okla. |
Kidding aside, Gerry, looks like the contact and condensation is creating rusting and eventually blow a hole in either one. Yes, I would definitely write this up. Marcel </IMG></IMG></IMG> Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ |
bbenjamin is a non-member guest and is in no way affiliated with InterNACHI or its members.
I want to say you need a least an inch clearance around the flue. You wouldn't want the flue to touch anything because of the temperatures of the gases being excavated from the unit. The problem can be corrected by making the elbow connected to the unit more of a straight 90 facing upwards.
Looks like its an attic installation and should be in b vent all the way from flu to cap and not touching any other objects.Matt
Yes I did write this up because of the lack of clearance and the rust/heat on the duct. My most concern was the fire potential on the inner insulation of this duct even though the insulation is somewhat fire resistance the glue that is used to hold the insulation to the metal is not alway fire resistance. I recommended the the duct be extended with a collar to provide proper clearance. Freedom Express Inspections LLC CMOR Thermography Certified Level 11 #2097 freedomexpressinspections.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F Professional Home Inspector State License # 130 Reporting system by Home Inspector Pro Serving the State of Okla. |
The information label on a furnace I inspected last week called for 5" of clearence for the flue.
| AHJ's opinion differs from code...how would you write it up? | jhugenroth | Plumbing | 9 | 8/31/09 9:04 PM |
| How would you write This | gporter | General Inspection Discussion | 12 | 9/24/07 3:38 PM |
| Tidbits from the ASHI Message Board | jbushart | Misc. Discussion | 124 | 4/27/07 12:05 PM |
| Write It up or not? | thejnicki | Electrical | 5 | 8/7/06 4:49 PM |
| How should I write this | gporter | HVAC | 7 | 6/29/06 4:27 PM |
