Would you require a WYE from the WH to the furnace flue?
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 Last edited by bhartley; 5/13/11 at 10:00 PM.. |
| Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Only if water heater or furnace has a inducer draft blower on the exhaust.
Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
But "Wye" ?
If that is a TEE connection then the flue is now a horizontal run at that section and violates the required 1/4" per foot rise needed to satisfy code does it not?.
That Tee has a reduction.
Is it 1/4" in 12"? Looks like it is, not that it really matters. Unless someone wants to get out their manometer ( what the F*** is that?) and measure the flue draft, I don't think there is anything to talk about here. This is going into a chimney, and the draft may be so great that it may require a barometric damper! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
