Old 8/25/06, 12:42 AM
jweinberg's Avatar
jweinberg jweinberg is offline
Please Note: jweinberg is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default York Age Convention doesn't work...
Newly installed brand new gas furnace
My cheat sheet says that the age convention on York HVAC systems is:
Year of make indicated by 3rd letter in the serial number.
The serial number is: W0A5480548
This only has 2 letters....
I'm thinking the 48th week of 2005.
Anyone care to confirm my assumption?????
Old 8/25/06, 8:19 AM
Russel Ray's Avatar
Default Re: York Age Convention doesn't work...
Are you positive about the first four digits? I've seen R and A look alike before, and R would be 2006. There are a lot of "48"s and "5"s there, aren't there?
Old 8/25/06, 11:20 AM
jweinberg's Avatar
Looks like an 'A' to me. Here is a picture....
Old 8/25/06, 12:26 PM
Russel Ray's Avatar
And if one compares the second digit of the serial number to the letter "O" in "Order," it's obvious that the second digit is the number "0," so we have letter-number-letter-number.
Interesting.
Old 8/25/06, 1:06 PM
Are you sure that is not the serial number to the coil pack, rather than the furnace?
Old 8/25/06, 1:08 PM
Russel Ray's Avatar
Good point, Blaine.
Old 8/25/06, 1:15 PM
Since 2005 models have a letter-number-letter-number configuration. (SN: W0E5195159)
W=city of manufacture 0=third digit of year E=month 5=fourth digit of year
(Wichita) 200-? May 2005
W0A5480548
In this case it's Witchita Jan 2005
Old 8/25/06, 7:25 PM
jweinberg's Avatar
I'm pretty sure it wasn't....
Good idea though...
Jeff
Old 8/25/06, 7:27 PM
jweinberg's Avatar
W0A5480548
I'll believe that Jae... Thanks!!
How did you know about this new serial number aging convention for York???
Old 8/26/06, 11:06 AM
David P. Valley's Avatar
Jeff,
I believe Blaine is correct.
Most Furnace data tags are glued to the inside of the cabinet (not outside).
The tag you posted appears to be on the exterior lower portion of the evaporator cabinet. Which is a clear indication that this is the manufacturers info. for the Evaporator.
Did you look inside the cabinet?
Old 8/26/06, 11:55 AM
jweinberg's Avatar
Originally Posted by dvalley
Jeff,
This was inside the cabinet.....right above the burner and right below the induced draft fan.
Contract Work in New Orleans Area kzimny Ancillary Inspection Services & Additional Topics 0 3/9/07 5:55 PM
Nachi Convention rcooke Canadian Inspectors 24 10/9/06 12:55 PM
Toronto Convention 2007 Update!!! twheeler Miscellaneous Discussion for Inspectors 0 4/30/06 6:10 PM
