| HVAC Topics include heating, venting, and air conditioning. |
I don't run into these very often and need help decoding the age from the S/N. Unitary Products Group is the manufacture. In this case it had the York name on it. I'm making an assumtion that GM has something do to with the year. Just don't know the sequence.
A/C Unit: Model H2DB024S06B Serial: (S) EGGM255175 Furnace: Model: P3URB10N05501B Serial: EFGM186034 Thanks in advance for your help! Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowlege will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.4squarehi.com Follow Us on Facebook Follow Us on Linked-In |
| Find an InterNACHI certified Montana Home Inspector (and anywhere else in North America) |
Is that consistant with the age of the house? "Never underestimate the difficulty of changing false beliefs by facts." |
Not even close! The home was built in 1913. It always makes it more of a challenge when it's a replacement furnace
I would have thought it was 10 to 15 years old not 20+ years. It's a two pipe heat exchanger 90% eff. Maybe 1991
Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowlege will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.4squarehi.com Follow Us on Facebook Follow Us on Linked-In Last edited by gliebig; 6/22/09 at 7:35 PM.. Reason: Added year |
EFG & EGG S/N looks like 1998 to me
Chuck Evans (TREC #7657) HomeCert Houston Home & Thermal Inspections Houston Infrared Thermography and Thermal Imaging Inspections Houston Home Inspector Houston, TX |
1977 or 1998 from my reference
Serialnumberforyork.pdf here you go
I think Wayne has it.
I read the wrong side of my chart for the letter G 1977 or 1998 (dag nabbit, read it wrong again) My chart says '77 or '98 "Never underestimate the difficulty of changing false beliefs by facts." Last edited by mlarson; 6/22/09 at 9:49 PM.. Reason: brain fart |
What was the ANSI year?
Owl Home Inspections Rick Maday Itasca, IL Home Inspector Serving all Chicago Suburbs Schaumburg Home Inspector Naperville Home Inspector Lake County Home Inspector
jbowman is a non-member guest and is in no way affiliated with InterNACHI or its members.
YORK(1971 to October 2004)
Date of Manufacture (1971 – October 2004): The manufacturing date code is the second and third digits of the serial number, written as Month and Year of manufacture. (To determine month: A = Jan; B = Feb; C = Mar; D = Apr; E = May; F = Jun; G = Jul; H = Aug; I was not used; J was not used; K = Sep; L = Oct; M = Nov; and N = Dec.). To determine year of manufacture:
Sample Serial Numbers: The year is indicated in Red and the month in Blue.
YORK(October 2004 to Present) Date of Manufacture (October 2004 to Present): The manufacturing date code is the second and third and fourth digits of the serial number. (To determine month: A = Jan; B = Feb; C = Mar; D = Apr; E = May; F = Jun; G = Jul; H = Aug; I was not used; J was not used; K = Sep; L = Oct; M = Nov; and N = Dec.). To determine the year of manufacture combine the 2nd and 4th digits of the serial number. Year 2nd Digit 4th Digit 2004 0 4 2005 0 5 2006 0 6 2007 0 7 2008 0 8 2009 0 9 2010 1 0 2011 1 1 2012 1 2 Sample Serial Numbers: The year is indicated in Red and the month in Blue.
List your business in our Home Inspector Registry with a link exchange. Check out your state now at http://hisearch.org/homeinspectorregistry.aspx Are you listed???
Could not see due to interference. And those lables are horrible to read! 1998 would be most correct as far as everything else with the system that I saw today.
Thanks!! Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowlege will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.4squarehi.com Follow Us on Facebook Follow Us on Linked-In |
| Age of Furnace Needed | pcarter1 | HVAC | 7 | 6/16/09 11:14 AM |
| Age of York furnace | jskrypka | HVAC | 2 | 5/23/09 4:22 PM |
| YORK Furnace and A/C Age? | crichiii | HVAC | 3 | 2/18/09 4:51 PM |
| 980 Questions/Answers to the NHIE....Free! | jbushart | Legislation, Licensing & Legal Issues | 50 | 4/20/08 2:26 AM |
| HVAC age | tspeerstra | General Inspection Discussion | 5 | 2/14/07 10:56 AM |
