Does this look right?
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 2/18/08 at 5:34 PM.. |
In what respect is your question? The unit appears to be level and clear of vegetation. It seems to be in sort of an alcove, but as long as it has breathing clearance it's O.K.
apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Popsicle
I do not think it can get much heat for the home . Roy Cooke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
On second look it does appear to be icing. I thought the first time it was blurred picture.
If it is ice, is it coming or going? It could be just ready to start its defrost cycle, or just finishing and not functioning properly. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Depending on the type of refrigerant.....
Newer heat pumps will ice up some normally, the defrost cycle is set with a DIP switch or jumper and may need to be changed to a shorter period but no less than 30 minutes. If it is an older unit it is probably low on refrigerant. |
York Heat Pump (1993)
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I have observed ice problems on heat pumps simply because the weep holes in the bottom of the unit were blocked with leaves or the unit was not raised off of the pad. |
That unit does have a circuit board. It's a time and temperature board with a thermister on the liquid line. Depending on conditions that appears to be too much frost. I would write it up and have an eval.
James R Lilly, CMIA www.lhiservices.com jamesrlilly@lhiservices.com Home and Mold Inspections Radon Testing Based in Parkersburg, WV Serving West Virginia and Ohio |
| York Heat Pump Age | Tab M. Wilcox | Inspecting HVAC Systems | 4 | 4/10/07 4:08 PM |
| York Heat Pump | Summer House | Inspecting HVAC Systems | 7 | 2/21/07 10:13 PM |
| York Heat Pump Help... | jbarnett2 | Miscellaneous Discussion for Inspectors | 3 | 1/28/07 1:15 PM |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 11:47 PM |
| Question on my heat pump | dbush | Inspecting HVAC Systems | 7 | 3/12/06 1:15 AM |
