Old 2/18/07, 10:26 PM
Summer House Summer House is offline
Please Note: Summer House is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default York Heat Pump
What would cause a York Heat pump to not run in heat mode but to run fine in cold? Neither compressor or outside fan run in heat, but fine in cooling. Indoor air handler and Aux. heat work fine. No ice on coils outside but very cold weather. Thanks
Old 2/19/07, 2:45 AM
JLilly's Avatar
JLilly JLilly is offline
Default Re: York Heat Pump
Some York heatpumps have a setting on the circuit board that locks out the outdoor unit below a set temperature. This temperature is adjustable.
James R Lilly, CMIA
www.lhiservices.com
jamesrlilly@lhiservices.com
Home and Mold Inspections Radon Testing
Based in Parkersburg, WV
Serving West Virginia and Ohio
Old 2/19/07, 7:01 AM
Russel Ray's Avatar
A bad reversing valve.
Old 2/19/07, 9:19 PM
The reversing valve clicks on AC. The compressor and fan run with a manual contact. Could you please tell me how to lower or check the setting on the circuit board. Is it one of the jumpers, red or blue, located on the outside of the module? Thank you for the quick response.
Old 2/19/07, 9:24 PM
Russel Ray's Avatar
You'd need the user manual. See if you can download it from the manufacturer's web site.
Old 2/21/07, 6:30 PM
bbenjamin bbenjamin is offline
Please Note: bbenjamin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Sounds like you are having some electrical issues which could be cause by incorrect wiring of the t-stat, air handler or compressor. I would check the low voltage, high voltage and wiring to start.
Old 2/21/07, 9:00 PM
Bruce A. King's Avatar
Also, the defrost board does a lot more than just control the defrost cycle on most units. A spare board off the internet is less than a service call from a tech.
www.BAKingHomeInspections.com
704 301-3207
Old 2/21/07, 10:13 PM
Thanks for all your help.
Removed bushes surrounding heat pump. Sun came out today, temp reached about 50. Heat pump is now running fine. Low Temp Cut Off was set at -10. Balance Point was set at 40. Perhaps the temp sensor was encased in ice. We'll see at the next cold snap. Thank you all for the incredibly fast responses. Good Network!
York Heat Pump Age Tab M. Wilcox Inspecting HVAC Systems 4 4/10/07 4:08 PM
York Heat Pump Help... jbarnett2 Miscellaneous Discussion for Inspectors 3 1/28/07 1:15 PM
York Heat Pump jhagarty Inspecting HVAC Systems 9 1/17/07 9:06 PM
Heat pump in a 80+ year old masonry house jskrypka Inspecting HVAC Systems 9 11/25/06 11:47 PM
Question on my heat pump dbush Inspecting HVAC Systems 7 3/12/06 1:15 AM
