Old 1/30/08, 4:12 PM
dmontgomery1's Avatar
dmontgomery1 dmontgomery1 is offline
Default You gotta see this!
One guess... I stared at this for several minutes in disbelief!
Yes... it is installed upside down. This guy did more work to make this work... would have been much easier to just run back to the shop and get the proper unit. It has been in this house like this for two years. Above it was also some undisclosed charring to the joists and decking. Also note the flex line running into the unit. You cant see it but the vent pipe is disconnected about two feet above the cabinet. Also missing a reducer for the vent pipe.
Kindest Regards,
Darren Montgomery, MBA
318-294-4444
Certified by the Louisiana State Board of Home Inspectors;
License #10575
National Association of Certified Home Inspectors;
License #07030403
International Code Council #5323222
Visit us on the web at: http://www.redriverinspections.com
Old 1/30/08, 4:18 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Default Re: You gotta see this!
Wow! Flip this house
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 1/30/08, 8:12 PM
Peter Foxe Smothers's Avatar
Peter Foxe Smothers Peter Foxe Smothers is offline
WoW!
Foxe Smothers ( Owner / Inspector )
Pelican State Inspection
Your Best Choice for Home Inspection in the Shreveport & Bossier City Area!
www.PelicanState.Net
www.ShreveportHomeInspector.net
www.BossierCityHomeInspector.net
foxe@pelicanstate.net
LSBHI #10399
Old 1/30/08, 9:24 PM
Troy Farmer's Avatar
Troy Farmer Troy Farmer is offline
Isn't it cool the stuff we get to see. Just when you think you have seen it all.
Darren Can I use this photo??
Troy Farmer
Presidential Inspections LLC
Chapter President Southern Idaho
PO Box 2144
Eagle, Idaho 83616
208-573-5300
http://www.presidentialinspection.com
http://info@presidentialinspection.com
"He who can, does. He who can’t, teaches"
"Where would we be without Teachers"
Old 1/30/08, 11:00 PM
Banned
About 5 years into my HI career, I was feeling pretty cocky, not having had any serious complaints against my work and, like you, thought I must have seen it all by now..........until......
I inspected a rural property that had a certified older wood/oil combination furnace. As I moved around to one side of it, out of the side of the original casing was a run of #2/3 cable. Upon further investigation, I found that the insides of the oil section had been removed and replaced with an electric forced air furnace, "lock, stock and barrel"! This invalidated any certifications on both units.
Asked the owner (an insurance salesman!!!!), "Who did the work?". "An electrician", he says. I ask "A Licensed electrician??" "Yes" says he. What!!!!! Since then my saying has been: "if I don't see something odd, bizarre, different, "what were they thinking" stupid every week, I must have had my eyes closed. And sure enough, in busy times, every week I find something.
Old 1/31/08, 12:55 PM
David A. Andersen's Avatar
http://www.furnacecompare.com/faq/de...iguration.html
Did you check to see if it could be done with this unit?
http://www.freepatentsonline.com/7036498.html
A problem I see with this is the a/c coil is on the downstream side of the heat exchanger. This causes a lot of condensation in the heat exchanger.
Old 1/31/08, 1:59 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
I caught myself turning my head sideways trying to see what might be wrong.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 1/31/08, 3:36 PM
Richard L. Bennett Richard L. Bennett is offline
This unit looks like it was made by confort air or they are using unit made by the same mfg
I think it might be OK -
Reason I say this I have one of their units and it is mounted on its side
Looks like its brother
rlb
Old 1/31/08, 4:07 PM
This unit is designed as for downdraft or horizontal applications only. It is mounted in an updraft configuration. But you are correct in that in a horizontal application it would be ok.
Cargo pants: Gotta love 'em! kshepard Miscellaneous Discussion for Inspectors 3 10/30/06 5:43 PM
