While inspecting a property recently I noticed a sidewall jet in the pool was aerating quite a bit - loud enough to catch my attention. I didn't see any controls for aeration in the pool so it made me wonder if that was by design or possibly a problem with the piping supplying that particular jet. Any insight or experience with this condition is appreciated.
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
If there is not an open standpipe somewhere that is acting as a scavenger to create bubbles then more than likely there is a hole or loose connection the piping somewhere.
Thanks for the advice Charles
It may be a hydrotherapy jet, some pool builders pipe the air intake quite far away. If not it's probably an air leak on the suction side of the plumbing, you should see air in the pumps lint pot (strainer).
5144 Atwood Terrace Inverness, FL 34452 352-212-3576
I would agree with the idea that there is a leak. Was the water level low? Was there a pool sweep running?
I would listen to Larry, that guy knows pools....
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Thank you Russell.
If the pool piping (we don't call it plumbing) is leaking on the return side (pressurized side) it will not cause air bubbles at the return fittings, air can't come in while water is leaking out. How ever if the piping is leaking on the suction side it would pull air in when the pump is running and unless the leak is between the lint pot and the pump body (very possible with some pumps) you will see air in the lint pot. Another check is to let any air that may have accumulated in the filter out through the (wait for it) air relief valve. Then let the pump run for a while and see if the air builds up again. I realize that messing with the valves etc. is beyond the SOP but I've been building, servicing and repairing these things for 34 years so I feel confident when I do it. 5144 Atwood Terrace Inverness, FL 34452 352-212-3576
Glad to be of some help.
| new law for pool motors | wsiegel | Florida Inspectors | 16 | 6/9/11 10:17 PM |
| Pool Executive Charged in Drain Death | jhagarty | Ancillary Inspection Services & Additional Topics | 1 | 7/23/08 11:15 PM |
| This House Met Code. | jbushart | Electrical Inspections | 88 | 1/16/08 12:29 PM |
