Old 2/14/11, 7:33 AM
Kevin T. McDade's Avatar
Kevin T. McDade Kevin T. McDade is offline
Default air test/epicoccum
Did Air samples in house last week. Not going to get into why, Basement kitchen and wall cavity. I used upstairs living room as clean room, because of lots of snow cover. Results cam back as living had 3% epicoccum, it was only in living room. There where no real plants in the room. Turns out client had just removed 2 huge pointsettas 2 weeks prior(which were in full bloom) Question is how long will it stay with in a room.
Can-Am Home Inspections Inc.
Level 1 Thermography
Specializing in Building Infrared Thermography
ProLab Certified
INACHI #09113003
IAC2 #01-8254
www.can-amhomeinspections.com
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/14/11, 11:38 AM
James E. Braun, CMI's Avatar
Default Re: air test/epicoccum
Probably for several months. It depends on how well the house breaths.
I would not worry about it because there is no studies linking this mold to any health effects.
Old 2/14/11, 12:49 PM
John M. Acaron's Avatar
John M. Acaron John M. Acaron is offline
If you did air samples inside the living space and you use a room that you think is clean then your results will be hosed. If you have the HVAC on (heat or cool) the same air is recirculating inside the living space. Yor results are no good.
John M. Acaron, BSME, CMI
HOMEINSPECTORUSA, LLC
State of Florida Licensed Home Inspector
State of Florida Licensed Mold Assessor
BSME & TDME (Mechanical Engineer)
Certified Master Home Inspector
Certified Indoor Air Consultant
Office: 850-814-3889
FAX: 850-249-8997
SEMPER FI
Old 2/14/11, 2:22 PM
Old 2/14/11, 3:26 PM
Thanks James
ProLab Certified
INACHI #09113003
IAC2 #01-8254
