Old 1/21/14, 10:24 PM
Sam Morris Sam Morris is offline
Default Asbestos Insulation ?
Inspected a house built in 1969 today and found what I think is asbestos insulation. I have near seen it to be in this good of shape. The inside was a yellow fiberglass insulation with a metal backing then the white fiber wrap. I know to recommend testing, but I wasn't even sure it was asbestos. I seen it 20 or more times over the years. Does anyone have any thoughts.
asbestos-insulation-carver-stewarthills-059.jpg   asbestos-insulation-carver-stewarthills-057.jpg   asbestos-insulation-carver-stewarthills-058.jpg
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/21/14, 10:27 PM
Bob Elliott's Avatar
Default Re: Asbestos Insulation ?
NO
Not asbestos.
The yellow foam gives it away.
Old 1/21/14, 11:12 PM
Originally Posted by belliott View Post
NO
Not asbestos.
Agree, Thank you
Old 3/26/14, 2:18 AM
Ronnie Keeling Ronnie Keeling is offline
Please Note: Ronnie Keeling is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think it is glass wool which is used to provide thermal insulation to steam and hot pipes like that of boilers and reactors and not asbestos. For steam tracing purpose we do use steam tracing ropes made of glass fiber particles which is white in color. The GI covering done looks good to me but there are some open parts where there are chances of these tiny particles to get escaped.
Old 3/26/14, 12:55 PM
Mike Auger's Avatar
Mike Auger Mike Auger is offline
not asbestos. this is generally a good look at asbestos pipe insulation.
Mike Auger, CMI
RI Reg. # 32856
RI Radon Lic. # RMC-142 RMB-096
(401) 578-4878
A U.S.A.F. Veteran Owned Company
Old 3/26/14, 1:11 PM
Mike Auger's Avatar
I updated my post to include a picture.
Mike Auger, CMI
RI Reg. # 32856
(401) 578-4878
Old 3/26/14, 1:28 PM
Linas Dapkus, CMI's Avatar
Linas Dapkus, CMI Linas Dapkus, CMI is offline
Fiberglass.
Linas Dapkus, CMI
Infraspection Institute Certified Infrared Thermographer Level III # 8510
Dapkus Home Inspections
Rated #1 Chicago home inspector since 2006.
Old 4/10/15, 12:44 PM
Kristofer J. Pagliaro Kristofer J. Pagliaro is offline
I found this blown on insulation on the garage concrete ceiling and piping wrap insulation on a pipe that ran through the garage and also on a pipe near the water heater of a unit in an apartment building. Can anyone tell me if these are asbestos insulations?
asbestos-insulation-img_6363.jpg   asbestos-insulation-img_6342.jpg   asbestos-insulation-img_6361.jpg   asbestos-insulation-img_6362.jpg   asbestos-insulation-img_6365.jpg
Poly being applied to Basement walls dvalley Interior Inspections 40 11/24/09 10:49 PM
Asbestos.............What is asbestos? mkyriacou Ancillary Inspection Services & Additional Topics 2 9/17/09 5:03 PM
Asbestos jmckenna1 Miscellaneous Discussion for Inspectors 0 1/26/07 11:11 PM
Asbestos jmckenna1 Miscellaneous Discussion for Inspectors 0 1/26/07 11:09 PM
