Good evening,
Anybody know of any on line classes for certification for asbestos testing and certification. Thanks Chuck |
Home inspectors do not perform tests for asbestos. You will probably need to contact a lab that does to see how they certify their employees.
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
You could get a course for taking samples, but testing requires a microscope. Even sampling is not as easy as it sounds. You could easily contaminate a home if taken incorrectly. Insurance for sampling can be very costly as well. Keep this in mind.
Rodney Misener, CMI Trinity Inspection Services Pictou County, Nova Scotia http://www.trinityinspectionservices.com Certified Home Inspector Certified Level 1 Thermographer Certified Energy Advisor WETT Certified Inspector IAC2 Radon/Mold Certified Infrared Certified |
Many states regulate that industry. Check with your state environmental regulation agency. Testing is simple,
Most states require at minimum an EPA Asbestos Building Inspector Certification and then many states require a State Certification as well. In order to perform Asbestos Inspections in Colorado, for example, you need an EPA certification and a State of Colorado Asbestos Builiding Inspector Certification. In order to get these, you need to go to classes and pass an EPA class and then take a State test (for Colorado). Then there is also annual continuing education as well. The lab you use to analyze the samples must also be NVLAP accredited as well.
I would check with your local state to see what their regulations are. Hope this is helpful |
| Lead Paint Testing Certification | ctolbert | Ancillary Inspection Services & Additional Topics | 2 | 12/26/09 2:53 PM |
| Liability question | jcahill | Legislation, Licensing & Legal Issues for Inspectors | 30 | 8/24/08 5:10 PM |
| 1-day well inspection and water testing certification in Manchester NH on Oct 7, 2006 | gromicko | Miscellaneous Discussion for Inspectors | 0 | 9/3/06 2:08 AM |
