Old 10/5/07, 3:59 PM
Aulden Reid's Avatar
Aulden Reid Aulden Reid is offline
Default Becoming a WETT inspector
I am wondering if any of you have any commnets on becoming a WETT (wood energy transfer technology) certified inspector. How much does it cost and is there enough work to justify it. I direct this to those living in the colder climates of course. I have been approached by a few insurance agents asking if I have the certification. I recall looking into it before and seem to remember it was expensive and difficult to achieve.
Aulden
Old 10/5/07, 7:11 PM
mdiplock's Avatar
mdiplock mdiplock is offline
Default Re: Becoming a WETT inspector
Totally depends on your location. There are 2 or 3 inspectors in my area that have Wett certificates. As for my I find it hard to justify the cost of the courses and keeping your certificate. If I come across a wood burning fireplace or stove I recommend that it be cleaned and swept by a Wett certified sweep. Just not alot of call for it here down in the Nothern banana belt. Then again, I know of other inspectors up north that pretty much have to have it in order to compete.
http://http://www.wettinc.ca/
a wise man once told me, "life is short, so learn from your mistakes, but more importantly learn from others mistakes as well because you don't have time to make them all yourself"
Regards,
Mark
Old 10/5/07, 10:27 PM
Thanks for you input.
I wonder if spending 1000.00 on the courses and not getting fully certified until I complete 60 inspections in no less then 80 weeks is practical. My Amerispec competition is certified but I am not worrying about that. I just thought it might be a good ancillerary service for this cold saskatchewan climate. Inspections are slow so I thought this certification might help me to get a few more inspections as well.
Aulden
Old 10/5/07, 10:59 PM
bjones1 bjones1 is offline
Send a message via MSN to bjones1
Please Note: bjones1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
'Round here, everyone and their uncle heat with wood. Being WETT certified would be a benefit up here. I had a call to go to Parry Sound just to do a WETT inspection. Turned it down, too far for too little.
Old 10/10/07, 6:43 AM
rwand1 rwand1 is offline
You only need WETT if you want to do inspections for insurers or for home insurance reasons. There is nothing stopping you from calling out issues with wood burning appliances if you do not want to become WETT certified, just don't expect the insurers to accept your recommendations for insurance purposes. And when in doubt about a set up refer to a WETT tech.
Old 10/11/07, 6:16 AM
Banned
Originally Posted by rwand1
You only need WETT if you want to do inspections for insurers or for home insurance reasons. (or to cover your own ***** by really knowing what to call.)
There is nothing stopping you from calling out issues with wood burning appliances if you do not want to become WETT certified, (But it may not be what you call but what you miss that counts. The WETT tech course is a full 5 days in the classroom and 80 weeks of field work. There's a reason for this!!) just don't expect the insurers to accept your recommendations for insurance purposes. And when in doubt about a set up refer to a WETT tech.
Be careful!! There's a lot more than meets the eye in good wood heating appliance inspections.
For example, there's a particular item I see with the masonry hearth-wood framed wall "thimble" or "pass through" to an exterior masonry chimney. Although I cannot see through or in the wall, I've called this unseen item probably more than 10-15 times in my career. The true determination of the fault requires breaking into the masonry hearth and wood wall. I tell people that if they break into the wall and find that it meets code requirements, I will pay for all their costs......I have yet to pay a cent!!!
Brian MacNeish
Master System Advisor
WETT #572
Old 10/11/07, 7:43 AM
Brian
Who are the people who are suppose to open the wall? The home owner? The WETT tech, or the insurance appraiser? How many remain unopened?
Have seen lots of wood appliances that don't meet combustible clearances and have also seen lots of so called Wett Inspections of chimneys where the WETT tech came in and okayed the chimney not having swept it.
So its like everything else I suppose, good and the bad and the ugly.
Old 10/13/07, 6:55 AM
Banned
Brian
A WETT tech should be called in by the vendor to check the call. If not, I recommend the buyers get an allowance of $800-$1,000 as a "cashback" at closing so they can get the hazard changed to a safe installation by a WETT tech.
If no one opens the wall and there is a fire, then my ***** is covered.......all part of my internal CMA (cover my *****) policy.
Old 10/13/07, 7:09 AM
If in doubt I usually state "further investigation by qualified tech, prior to close of title." That way the vendor is responsible for any noted concerns at their cost and not the purchaser.
Old 10/13/07, 12:00 PM
jcote's Avatar
jcote jcote is offline
For me that the best way to go,I don't spent much time on wood appliance,insurance will require that a wett cert. do the inspection anyway.
Jeannot
Old 10/13/07, 12:39 PM
Roy D. Cooke, Sr's Avatar
I did the WETT courses and decided not to write the final exam .
To me is was just an added liability I did not want or need .
Regardless they still need to be cleaned so I just pass this on the the person who they get to service the appliance.
We have a couple of home Inspectors ( ex NACHI Members ) who give free WETT inspection with the home inspection.
They also Charge less then we do .
It has not hurt me business so it is obvious they must be desperate for work to do WETT inspections for free.
I am surprised that WETT allows those who never work or install wood appliances to do WETT inspections .
This of course takes work away from those who work on wood burning appliances.
Old 10/13/07, 1:47 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
This is the website for WETT for those of you that are interested.
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 10/13/07, 3:02 PM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
Aluden;
Look into Eco Energy $$$$$$$$$$$$$$$ busy as heck
Cheers
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Old 10/13/07, 11:12 PM
Thanks Everyone, good food for thought. It is great to have professionals like yourselves that I can bounce these things off. I will give more thought and research before I do anything.
Aulden
Old 10/16/07, 10:27 PM
gporter's Avatar
gporter gporter is offline
Originally Posted by dcossar
Aluden;
Cheers
What is that.
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
WETT Inspection ccrooker Canadian Inspectors 7 4/11/07 6:12 AM
E&O Insurance for WETT Members phinsperger Canadian Inspectors 0 12/10/06 2:25 PM
Mason Say's "OK" twheeler Inspecting HVAC Systems 18 1/18/06 9:36 AM
