----- Original Message ----- Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
I could not find the meaning of the word ( hydrofractured?) but I think she means where they put down dynamite in the hole fill it with water to fracture the rock. We have an area 3 miles from here where a Friend on mine has 60 acres .. He had 5 wells drilled down about 100 ± feet and they all where dry . They put two sticks of dynamite down filled it with water . Out came the 22 feet of 6 well pipe and it went straight up so far it looked like a cigar . It came down about 200 feet from where they where and stuck in the ground badly bent . They had to cut if off could not pull it out . Next well 1 stick of dynamite same thing straight up and it came down fifty feet away only this one landed almost flat destroyed another well pipe . 1/2 stick in the next three out came the water but the pipes stayed down . they where about two hundred feet from houses . One well was only fifty feet from the Murray Canal He got zero water from all the wells.. No damage to any homes . Roy Cooke sr |
rbunzel is a non-member guest and is in no way affiliated with InterNACHI or its members.
Roy,
The TNT trick was/is old Bubba technique. My understanding is well companies are using high pressure water to open new seams to let the water into the well. Hence the term hydro fracture. I don't have any experience with it but spoke to a well guy who told me it was an option on some wells. I guess the good ol boys didn't consider pulling the pipe before they dropped the dynamite!! //Rick |
| Home Inspection Business Part Time (Seeking Advice) | Shawn M. Nold | General Inspection Discussion | 32 | 9/16/07 11:58 AM |
| Recall Notice - CPSC Notice | pabernathy | Electrical Inspections | 1 | 1/25/07 7:34 PM |
| Consumer Confidence | jmckenna1 | Miscellaneous Discussion for Inspectors | 0 | 11/20/06 1:38 AM |
| Consumer seeking thremal imaging inspection in Pennsylvania. Help. | gromicko | Miscellaneous Discussion for Inspectors | 0 | 6/8/06 1:21 AM |
