Old 9/15/08, 1:41 PM
sfalvey sfalvey is offline
Default Difference between PVC and
Well supply line is of PVC-1. Is there any difference between this and PVC? I know CPVC is "acceptable" for potable water, but how about PVC-1?
Thanks,
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 9/15/08, 1:45 PM
Michael Larson's Avatar
Default Re: Difference between PVC and
PVC-1 is a movie
I assume the 1 is for 1 inch.
PVC is fine for cold water applications though I have not seen it used for well supply line.
A photo might be helpful
Michael Larson
Hudson, WI
[/I]
Old 9/15/08, 1:47 PM
Christopher Currins's Avatar
1 inch
Christopher Currins
Certified, Licensed
Old 9/15/08, 1:49 PM
Here ya go.
Scott Falvey
Newbury, NH
NACHI#05051292
Old 9/15/08, 1:51 PM
Originally Posted by ccurrins View Post
1 inch
Da, makes sense. I guess that was pretty stupid.
Still I have never seen/heard of PVC being acceptable for drinking water?
Scott Falvey
Newbury, NH
NACHI#05051292
Old 9/15/08, 4:19 PM
Terry Clayton Terry Clayton is offline
Just asking what the clean out is for, 1st look I thought it was part of a drain
Old 9/15/08, 4:42 PM
I noticed that too.
It looks like amateur work to me. JMHO
The boiler drain is upside down.
The transitions fitting from PVC to the bronze/brass (check?) do not look like fittings rated for that purpose. They have a seal and or are PVC on one end and metal on the other.
Michael Larson
Hudson, WI
[/I]
Old 9/15/08, 5:18 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
The spring loaded check is in the right place, but it effectively lowers the pipe size to 3/4. The check valve should be full port on a well pump line. If I'm not mistaken it looks like schedule 40 (DWV) which is not approved around here (I could be wrong).
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
