Old 10/5/09, 5:23 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default How do you inspect the garage door?
According to the Res. SOP:
2.10. Doors, Windows & Interior
I. The inspector shall:
D. inspect garage doors and garage door openers by operating
first by remote (if available), and then by the installed automatic
door control.
What is an "automatic" door control? Is that referring to the push button switch mounted usually on the wall? What's automatic about a button?
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America)
Old 10/5/09, 5:40 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: How do you inspect the garage door?
Ben,
Seems like you've gone over the SOP with a fine tooth comb. Kudos to you.
IMO, discussion of the SOP and how it should apply or suggestions for changes, improvements or clarification are better discussed in members only.
Old 10/5/09, 9:10 PM
James E. Braun, CMI's Avatar
What would make the difference if we opened the door with the remote last?
Old 10/6/09, 12:55 AM
Paul Pendley Paul Pendley is offline
I never...push the button without looking at the guides/springs/slides first.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 10/6/09, 12:57 AM
I will actually open the door manually if all seems ok before operating the auto opener.
Paul Pendley
866-458-8516
Old 10/6/09, 3:59 AM
Russel Ray's Avatar
Originally Posted by bgromicko View Post
Attachment 32406
door control.
If you push the button, the door automatically goes down or up. You don't have to walk over to the door and physically push it up or down since it's automatic once that button is pushed.
Old 10/6/09, 7:31 AM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
If you say "Open Sesame" and the door opens, then that is an automatic door!
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 10/6/09, 10:53 AM
door control.
The SOP requires you to operate the garage (ie. open and close) FIRST with the remote. You have to open the open the door with the remote FIRST.
Why?
And what happens legally if you do not follow the SOP? Are you exposing yourself to legal problems?
BEN GROMICKO
Old 10/6/09, 11:02 AM
Michael Larson's Avatar
Now you're just being silly.
Michael Larson
Hudson, WI
[/I]
Old 10/6/09, 11:36 AM
maybe a little with this particular examination of this SOP clause...
but the bigger point - the SOP is designed to protect us - it should be under constant scrutiny and evaluation. (without an emotional outbreak from those not interested in that task)
BEN GROMICKO
Old 10/7/09, 9:18 AM
What would be the defense if you said that you followed the SOP but you opened up the garage door first with a button instead of a remote?
Old 10/7/09, 9:21 AM
Is there some functional difference that happens with the remote vs. the button?
This is a minor technicality with no significant meaning.
a.k.a. silly
Michael Larson
Hudson, WI
[/I]
Old 10/7/09, 9:32 AM
I agree, I think it needs to be removed from our SOP. Can somebody from NACHI please remove the phrasing so we can perform the inspection either way.
Thanks, Ben, for pointing this out.
Old 10/7/09, 6:22 PM
Where I come from....... GROSS NEGLIGENCE and WILLFUL MISCONDUCT!
hee hee
My point is not actually these small details of the SOP that seem "in need of tweeking" IMHO. Such as....
E. and report as in need of repair any installed electronic sensors
that are not operable or not installed at proper heights above
the garage door;
Sensors should not be installed ABOVE the garage door. Correction to the SOP is obviously needed here.
The main point for me is:
I'm doing what I believe we all should be doing. Evaluating and scrutinizing the SOP that is designed to assist us in our profession. I bet most of us have not even read the SOP in detail (and with a little devil's advocate inside us).
I encourage all inspectors to:
Once a year - take a look at the SOP, and ask "Is this the best? Can this be improved? Is there something missing? Should it be written differently?"
I'm just trying to "sharpen the iron."
BEN GROMICKO
Old 10/7/09, 10:36 PM
wsiegel wsiegel is offline
How many inspectors actually use the remote. I have never used one. If you want to clean up the SOP then remove that line. FYI - it might be a good idea to have it removed. If you ever go to court and say you follow the SOP, the opposing lawyer can make you look silly over something stupid like this.
Garage door inspection procedure bgromicko General Inspection Discussion 5 8/7/09 12:47 PM
Garage ceiling & door header Al Barb Interior Inspections 7 3/27/07 12:07 PM
Garage Door Safety...No Reverse...Advice Please gliebig Exterior Inspections 33 3/17/07 7:28 PM
