Is it common for a built in fiberglass pool's sidewall to
rupture if the pool has been empty for over a year. The pool's is 9ft deep. As I walked on the surface of the pool I could feel the fiberglass crunching as I walked. David ![]() ![]()
An Ounce of prevention is better than a pound of cure :} |
| Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
DO NOT DRAIN YOUR POOL
Your fiberglass pool is designed to remain full of water at all times. If the pool is drained without proper directions, hydrostatic or ground pressure outside the pool could cause the structure to buckle or crack. All damage to the pool shell resulting from improper pool drainage is the owners responsibility. If it becomes necessary to drain the pool, contact your Dealer or Pool manufacturer. installed for san juan, parkhill & dolphin pools back in the day Anyone having swimming pool, hot tub or spa problems with their residential or commercial properties is free to contact me at 972-487-5634 ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Barry is right on here. Even non fiberglass pools can be effected by hydrostatic pressure. Often in a concrete pool when work is being done a couple holes will be drilled in the bottom of the pool to keep the water from pushing it up. Hydrostatic forces can be 10x more than dirt alone.
Thanks Barry and Robert.....
That's the insight I was looking for. An Ounce of prevention is better than a pound of cure :} |
David
To add to what others have said, these pools can float up out of the ground if the soil gets saturated. As said NEVER DRAIN A POOL without some input from a professional. |
Don't forget the uv damage also can break down the lining of the pool if it does not have protection on the bottom with water.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
For every action there is an equal and opposite reaction.
Pete Campbell pete4545@comcast.net http://www.PortStLucieInspections.com http://www.ChooseGI.com http://ifwemissitwewillfixit.com Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida. |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| pool question | wsiegel | Ancillary Inspection Services & Additional Topics | 4 | 11/4/06 9:48 PM |
