Old 5/14/06, 8:58 PM
psiposs psiposs is offline
Send a message via Yahoo to psiposs
Default Fireplace damper does not close completely
Other than an energy efficiency issue what is the problem here?
Old 5/14/06, 9:21 PM
Doug Edwards,  CMI's Avatar
Default Re: Fireplace damper does not close completely
Item is not working properly or as intended. Stick to the facts. If it were the front door that wouldn't close all the way no one would have a problem understanding why it was a problem. Same goes for anything else that isn't working as it is intended. Its faulty, fix it or replace it.
Old 5/14/06, 9:51 PM
Joe Funderburk, CMI's Avatar
Check the local codes. If the gas logs are vented, some municipal codes require that the damper NOT close. That's what I was told, anyway, in a county where I often work.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 5/14/06, 11:53 PM
jmichalski's Avatar
jmichalski jmichalski is offline
Please Note: jmichalski is a non-member guest and is in no way affiliated with InterNACHI or its members.
Typically, the dampers that are required not to close are for vented gas units. That is a standard code now, although it can lead to drafts and irritating noises in the FP if installed poorly. (I suppose the issue that lead to the requirement is exhaust gases entering the home when someone forgot to open the damper and didn't have a lot of black smoke in the house to remind them).
For a conventional FP, I am not aware of any jurisdiction near my area that requires an open damper.
I agree that any hole in a house - even the damper - is a hole in the house. Serious energy loss - that alone should be enough. But why is the damper not closing? Age? Build up? Any of those items indicates that further inspection by a qualified chimney specialist would be warranted.
Old 5/15/06, 12:06 AM
rwand1 rwand1 is offline
You can also get birds, bats, squirrels in the house if the damper does not close completely.
Old 5/15/06, 2:55 AM
Russel Ray's Avatar
Hopefully one has a rain cap and spark arrestors on the chimney to prevent that.
Old 5/15/06, 3:01 AM
Russel Ray's Avatar
If one is asleep, one will not see the black smoke, and there won't be too much black smoke from gas fireplaces.
Weird Al Yankovic's parents lived in Fallbrook, an out-in-the-boondocks suburb of San Diego. His parents fell asleep with the cozy gas fireplace still going. This is the original story:
http://www.usatoday.com/life/music/2...-parents_x.htm
Of course, the papers rarely provide us with any follow-up. It turns out that his parents had started a wood fire in their gas fireplace and were using the gas fixture to keep the wood well lighted. The damper did not have a safety clip on it, so it was closed all the way. His parents did not wake up, having died from carbon monoxide poisoning.
Remember that a byproduct of burning organic materials is carbon monoxide. The reason why the safety clip is required on gas fireplaces and not on wood-burning fireplaces is because there is an unlimited supply of gas which will just keep burning and burning and burning, thereby emitting an unlimited supply of carbon monoxide. Wood-burning fireplaces eventually run out of fuel, so there will be a limited production of carbon monoxide and a possibility of people waking up when the fire goes out. With gas, the fire doesn't go out.
Unfortunately, too many people think that the whole purpose of the gas fixture is to make sure the wood fire doesn't go out. Stupid, stupid, stupid. We've got to educate folks, folks.
Old 5/15/06, 7:49 AM
Hopefully is the key word. Many, many do not have screens. Last time I checked a damper in a basement fireplace I had trouble opening the damper. Finally I really put my weight behind it, and shone my flashlight up into the damper, only to be stared at by Mama Racoon. Needless to say I closed that damper PDQ!
Old 5/15/06, 10:47 AM
Russel Ray's Avatar
One does not want wildlife living in the chimney, so I would choose to install a rain cap and spark arrestors before installing a damper. I think installing the rain cap/spark arrestors also is less expensive than installing a damper.
Old 5/15/06, 10:59 AM
jmichalski's Avatar
RR - that was my point about the gas FPs and the reason, as I undersatnd it, that many codes call for permanently open dampers on them.
I have not seen such a requirement for teh conventional FPS....not to say they don't exist, just that I am not aware of them.
Old 5/15/06, 11:00 AM
jmichalski's Avatar
I'm all for education, but sometimes you just can't overcome Natural Selection.
Old 5/16/06, 9:18 PM
I guess some people, due to geographic locations, a damper does not mean much to them. Maine is a different look on these parts of the fireplace for obvious reasons.
Since the fireplaces work most often than not, rodents, birds, and critters is not quite an issue. Since the roofs are so darn cold, why install a spark arrestor, it is cold before it hits the roof anyways.
Unless you have a Rumford Design fireplace here to convect the heat needed in the Winter time, I would not even fire it up if it does not have a damper.
I have one in my house and never use it because it is a useless installation.
Marcel
Old 7/31/08, 4:55 PM
Jason Raddenbach Jason Raddenbach is offline
Please Note: Jason Raddenbach is a non-member guest and is in no way affiliated with InterNACHI or its members.
Lightbulb Fireplace damper can be replaced
It is true that the building codes since 1991 have not allowed the use of fireplace dampers in new vented gas log setups. Most installers put in a clip that will not allow the damper to close after the gas log is installed.
A chimney balloon is an allowable substitute for a damper since it is not a permanent fixture in the fireplace and it will release if introduced to heat. So the homeowner can still close their flue off and not allow outside air to rush in and heat to rush out.
Old 7/31/08, 5:12 PM
Michael Larson's Avatar
Default Re: Fireplace damper can be replaced
Just another non member vendor folks.
http://www.chimneyballoon.us/chimneyballoon.html
http://www.chimneyballoonusa.com/blo.../04/index.html
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 7/31/08, 5:46 PM
Russel Ray's Avatar
We have dampers in all new vented gas log setups here in San Diego. However, a safety clip on the damper is a requirement.
Home Inspector Listings jbowman Miscellaneous Discussion for Inspectors 225 10/18/11 7:54 PM
Gas Fireplace Damper bkelly2 Inspecting HVAC Systems 1 9/16/08 12:10 PM
The Rumford Fireplace: Safety vs. Efficiency mbryan Interior Inspections 2 4/28/08 5:38 PM
Soot from Barometric Draft Damper (posted by Ted Hull) AskNACHI.org AskNACHI.org Inspection Questions Forum 3 5/11/07 7:49 AM
