I was inspecting a house here in Southern Calif., the house was build in the late 60's. In inspecting the attic, the insulation that I found was laid in and is a fiberous white and brown material resembling cotton and wool. I do not believe it is asbestos but I want to make sure. Anyone have experience or can identify this material. Just as an added note, the heating/cooling ducting was covered in the asbestos corrgated material.
Some additional information. When I held the material out in direct sunlight, the white material was fiberous and looked like spun glass. The brown material looked like paper or wood. When I took flame to it the brown material burned off and the white material turned black. Any thought or insights would be most helpful.
Sounds like a mixture of loose fill fiberglass and cellulose.
Foxe Smothers ( Owner / Inspector ) Pelican State Inspection Your Best Choice for Home Inspection in the Shreveport & Bossier City Area! www.PelicanState.Net www.ShreveportHomeInspector.net www.BossierCityHomeInspector.net foxe@pelicanstate.net LSBHI #10399 |
Do you know the answer, or are you looking for an answer? If you're looking for an answer, I would caution that it may contain asbestos and recommend that it be verified through laboratory testing. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Identifing Duct Material (Transite?) | mthomas2 | Inspecting HVAC Systems | 6 | 11/26/07 1:00 PM |
| Asbestos | jlybolt | Exterior Inspections | 41 | 7/17/07 1:13 AM |
| Help with identifying vent material | mthomas2 | Inspecting HVAC Systems | 3 | 1/1/07 12:10 AM |
