I just completed my Level one IR training and was trying to decide if I made the right choice. My thinking was to learn the basics of the camera as my top priority v/s less camera and more on building science. I have not attended building science so do not know how much camera was covered in that course would be interested in knowing from someone that did attend building science. My instructor in his opinion stated that I made the right choice in starting IR training with level one.
As I am thinking of buying an IR camera, I have been reading posts related to them. It is my understanding, so far, that the Building Science class includes most of the IR Level One class as well as more things.
I look forward to what others say. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I took the Building Science class based on John's revelations in this thread:
http://www.nachi.org/forum/showthrea...ilding+science |
BS covers 80% of LEVEL I. (In 1.5 days I might add! )
I think that they spend less time on Quantitative stuff as it has little application in what we use it for. Not that we did not learn it though. We did an application to determine the R-Value of the building envelope which requires temp measurement for the calculations. A lot of folks in my BS course had taken the Level I already. They were as a lost as I was, so they can't be too much the same! I think HI's should take the Building Science course as it applies. |
ALL the Level I, Level II, and Level III folks in my BS course said that the
BS course covered about 80% of the Level I details. The BS course was viewed by THEM as something geared more for real world applications of the IR camera for the use in building inspections. Some feel that the Level I course is superior based on the assumption that it is has been recognized by the industry as the beginning IR course that has been in place for years now. The Building Science course is a more recent development that evolved out of the need to teach the uses of the IR camera in the field of building inspections. Level I is recognized by NETA (International Electrical Testing Association, an accredited standards developer for the American National Standards Institute, ANSI). BUT... this is a little mis-leading to the novice because home inspectors do not inspect according to NETA or ANSI standards. Therefore their HI reports are not recognized, even if they have Level I certification. Many are suprised to learn this later. Does this matter? No. Home inspectors need to comply with their own SoP and do not need most of the scientific methods of testing, measuring, and documenting defects discovered at an inspection. Example: If moisture is discovered in a ceiling, does it matter what the temperature is? No.... Does it matter what the emissivity level of the ceiling materials are? No.... Does it matter that an intense formula be used to prove your report data? No... A moisture meter can verify the moisture problem and the camera can take a picture and document the location. That's it. So, in the home inspectors case... how to use the camera, learning some tricks of the trade and how to avoid false readings is the most important things they need. This is what most of the IR Building Science course deals with, plus 80% of Level I. Is Level I enough to equip a home inspector to go out and use the IR camera? Yes... your experience will do the rest. IMHO. John McKenna, CMI (TREC #4565)
I intend to use my camera for the inspection business but my business plan is to separate my Hi and the IR into separate business as I want to venture into industrial/commercial with the IR. My plan is to go back and take BS but also want level 2. I guess it is a matter of the chicken and the egg My instructor was a level 3 and he stated that there are 13,000 certified IR with only 50 being certified as level 3. FLIR has 5 level 3 employed with them. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
machinery, equipment, electrical systems and transformers, etc... then you probably need to go to the Level II training and also buy the higher end IR camera. The BCAM serves the residential home inspector well, but beyond that it will not meet your needs... IMHO. I talked to a Level III guy at our class and he said the BS course would be a must for any home inspector in his opinion. He said the BS course left him lost in the woods like a child. It is a lot to learn for the person that does not have a strong construction background. He dealt with mainly diagnosing electrical systems and power line maintenance for a industrial power company in his area. John McKenna, CMI (TREC #4565)
You are absolutely correct the B-cam is the bottom of the line and will serve the Hi well and yes I will purchase a high end camera for my industrial work. There were several students that brought their companies 920 and 930 cameras to class no comparison to the B-cam made me feel like placing my lonely B-Cam back in its case. But I didn't </IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Hey Charlie,
Have you ever been a member of the Armed Forces? I had a commanding officer with a name that was similar to yours. Send me a P.M. if you have. Thanks |
I also learned that breast implants have different signatures and can be "seen" with the Cam.
A Power line switch is small and a long way off. Home Inspection is up close and lack of wide angle makes you take two or more pictures which gives you 200 - 300 % increase in resolution. I like my BCAM. I runs and runs and can take a beating! |
I like my B-cam also but has its limitations works just fine for the Hi but I want more. You know the saying more is better and I am not referring to women My instructor spent a tremendous amount of time on emissivity and T-reflective and stated that the pages of tables in the back of the training manual for level 1 on emissivity should not be heavily used. What is your take on this??? </IMG></IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
You are working towards another area of IR. I'm not saying that bigger is not better when you can put it to use. Just that much HI stuff can be done at the lower levels. I don't think I would hang out of a helicopter with my BCAM! I'm already planning for my next CAM. But I have 4 different flashlights too! Quote:
There is a wide range of potential emissivity in the same substance. In Building Science they all but told us to throw it all out in building inspection! "Clean out all the clutter in the scan". Did they offer solution of adding a black body paint/substance instead of using the tables? Did he mean to not worry about it with the camera and add it later in the software? |
Yes I am going to take IR beyond HI I have a lot of old contacts in the oil refinery's and a brother consulting on drilling rigs there are a lot of totally electric drilling rigs that could use IR. </IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
| Stupid ASHI legislatin in Washington DEAD. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 20 | 1/29/08 10:05 AM |
| Building Science Links | mcyr | General Inspection Discussion | 3 | 8/11/07 1:06 PM |
| Article on Commercial and Residential Inspections and Assessment | mcyr | Commercial Inspections | 2 | 8/6/07 2:26 AM |
