Revel L. Thom is a non-member guest and is in no way affiliated with InterNACHI or its members.
If home inspectors can choose to sub-out to pest control companies during inspections, why not sub out to qualified pool professionals at the same time? Or at least advise homeowners to get the right help for their pool. Some home inspectors include pool inspections on their checklist but do they actually conduct a detailed inspection or just a quick 'once over'.
Are they inspecting the salt generators, the time clocks and their independant motors, the effiecency of the pool motor, the correct size filter, the heater and its burner tray(gas), coping and tile settlement, cracked risers behind tiles, leaks in the pool, signs of epoxy putty in the skimmer and around the jets, functionality of the main drain and verifying it's suction or lack thereof, safety lines installed for main drains, vacuum safety locks for pool cleaners, lights and their transformers, old 110 volt lights still hooked up to old deck boxes beneath new 1" pavers or spraydeck, "jandy" valves sucking air, code compliant drain covers, cut or capped pipes that spell uncompletion or elimination of hydraulic lines- usually a quick out for home sellers, automation systems and their actuators, infinity troughs and auto fills, child barriers and fences with their self closing gates and 52 inch high latches. Just a few of many items on the checklist that would probably add 3 hrs to your already 3 hr inspection. Do you really have the time is the question? If there is a pool at the residence it should be mandatory that the new owner have it inspected by a licensed swimming pool contractor(not just a cpo class license). MMM! |
A typical pool inspection takes about 1 hour and yes I am certified. I did not sub out WDIIR's either.
It is not possible to correctly 'inspect' a pool and it's hydraulics in 1 hour, unless the pool is 1 week old. But then again everyone's definition of pool inspection can be different. Surely there are guidelines per trade for inspectors to go by! I'd like to see the swimming pool checklist.
Then I guess we should "sub-out" electrical inspections. In fact, we probably can't "thouroughly" inspect the plumbing system either, so we'll need a plumber. Hell, while we're at it, let's bring out a structural engineer. . .
There are more than just "guidelines" and checklists. There is actual training involved to become qualified. If the inspector has not received proper training, they shouldn't be inspecting pools and spas. Sorry Revel. You'll have to get your business some other way. I won't be sending it to you. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Some inspectors will be more invasive and technical than others on the pool, which is no different than on the house. Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Don Peterson, CMI AmeriDream Home Inspections Inc. NYS License: 16000014560 |
Don't be rediculous Jeffrey, 'm not asking for your business, I'm asking that you guys take a different approach when inspecting pools. I don't need your business Jeffrey, kinda tough when you're in California and I'm in Florida don't you think. You say you inspect pools but I don't think you can give the homeowner their money'sworth by doing a onceover. There's more to a pool than just looking at it. Wake up and smell the coffee!
Your line of thinking suggests that all systems should only be inspected by "specialists" rather than "generalists," to which I disagree. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
jgroves is a non-member guest and is in no way affiliated with InterNACHI or its members.
Must be part of the NACHI Exam statistics. ha. ha. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I'm assuming he is a pool contractor. With that I am reminded of a recent builder (general contractor) who insisted that we are not qualified to inspect homes that he has built.
To the contractors who feel they build the perfect homes/pools/bridges/whatever, I say "thank you." Thank you for keeping me in business. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I'm in Florida and he isn't getting my business either. I had an A/C contractor tell me the same thing. It is is my agreement and I also let my clients know verbally that the inspection is visual and not intrusive.
This may vary from state to state. I only know about Texas, you live in another country http://www.nspf.org/ CPO and CPI certification is the way to go IMHO ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
| Buckeye Home Inspections Service Area | sboyd2 | Miscellaneous Discussion for Inspectors | 3 | 9/4/06 8:21 PM |
| Pool inspections/ valve check | dbucknavich | Ancillary Inspection Services & Additional Topics | 1 | 6/21/06 4:33 PM |
