Old 6/29/10, 10:24 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default Masonry fireplace hearth is both floor and projection
I was reviewing an inspector's report due to a claim, and I realized that there was a little confusion about what a hearth is.
For masonry fireplaces, a hearth includes both the floor of the fire box and the projection in front of it. The hearth should be made of masonry or concrete. Should be supported by non-combustible materials. And a hearth should be reinforced to carry its own weight and all imposed loads.
There should not be any combustible materials remaining, installed up against the underside of the hearth and hearth extension after construction. That would be a potential fire hazard that ought to be reported IMHO. I look for that piece of plywood under the hearth extension, as seen from the basement or crawlspace ceiling.
The hearth should be at least 4 inches thick. The hearth extension should be at least 2 inches thick. But there's an exception.
The hearth extension must be 2 inches thick unless the bottom of the fireplace opening is raised at least 8 inches above the top of the hearth extension. In that situation, the hearth extension thickness can be reduced to 3/8-inch thick. Brick, concrete, stone or other approved noncombustible materials can be used.
http://www.nachi.org/gallery/images/...extensions.jpg
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/29/10, 11:02 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Default Re: Masonry fireplace hearth is both floor and projection
Hmmmm...Ya think wiring is considered a combustible material? Panel was installed directly under the hearth extension for a fireplace on the first floor. Hearth and extension both had multiple cracks in the mortar and bricks. You could see light from the first floor when loking up at the underside of the fireplace. There is a fire waiting to happen!
Old 6/30/10, 8:37 AM
Joe Funderburk, CMI's Avatar
Good post. Thanks.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 7/6/10, 7:36 PM
Larry J. Michael Larry J. Michael is offline
Thanks for the info.
Greensboro Home Inspection
Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas.
greensboro-home-inspection.html
Raleigh Home Inspection
Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas.
Raleigh-home-inspection.html
BassRumors.com
Providing a blog, news, and forum dedicated to bass fishing.
