Old 1/11/08, 5:47 PM
Bruce A. Cargin's Avatar
Bruce A. Cargin Bruce A. Cargin is offline
Default Methamphetamine test
I was asked today if there was a way to test if a property had been used to produce methamphetamine. I have never heard of one but I'm asking the collective, any thoughts?
Bruce Cargin
Hastings, MN
Old 1/11/08, 8:29 PM
Richard A. Moran, 2nd Richard A. Moran, 2nd is offline
Default Re: Methamphetamine test
heck here:
http://www.inspection-perfection.com...der%20test.htm
Dick
Dick Moran
True Blue Home Inspections
A Div of RAM2, LLC.
Clarksville, MD
240-832-6838
MD Home Inspector License 29927
Old 1/11/08, 10:29 PM
Thanks Dick, I really did not think there would be a viable test for the following reasons, most of the chemicals used are common household items so false positives would be a problem and testing for meth itself seems problematic because each "chef" has their own "recipe". I guess there is a way to test. Thanks for the link.
Bruce
Old 1/12/08, 8:03 PM
Russell Spriggs's Avatar
Russell Spriggs Russell Spriggs is offline
Originally Posted by rmoran
Yes, I originally bought some from Carl, who buys them from the manufacturer. Also check out:
http://scottcompany.com/p-mrs.htm
for 85 cents each.
And, If you want a lab test, email me for the lab's info:
Russ @ cdaInspector.com
Old 1/12/08, 8:17 PM
ldapkus ldapkus is offline
Bruce
I've heard that if you lick 1 sq.ft. of a suspect area and start ricocheting off the walls, IT"S POSITIVE!!!
Old 1/31/08, 9:33 AM
jdouglass jdouglass is offline
I had the same question come up in a meeting with some real estate agents, one of them suggested that spray starch when sprayed on a suspected area would turn red a reaction with the chemicals used to manufacture the meth, another one said a potato cut in half then rubbed on the area. both sound a little down home and a little quirkier.We need a good reliable test that can detect METH this is a real problem that we all face any help on this subject needs to be posted thanks Jim D
Old 1/31/08, 12:44 PM
Hey, Jim!
Yep, I'd love to be there when the "deal is blown" because the agent has a potato slice in one hand and a can of spray starch in the other!
I agree, we need some quality testing. the lab I use would not be able to handle the NACHI volume.
Nick has asked me to create a Meth Course for NACHI, and we are looking into a national lab to provide support to NACHI members.
Old 1/31/08, 6:21 PM
tchristopher tchristopher is offline
Russ,
In your humble opinion, do you think that the swab tests from Scott Co. be okay to use with a disclaimer to reccommend a second test thru a lab if positive test results were found on the first one. You would think so since they say these are what the cops use to put you in jail with no disclaimer & or 2nd test option..
Old 1/31/08, 7:15 PM
Originally Posted by tchristopher
Russ,
Exactly, TJ!
That's how I "sniff" for my lab testing.
Old 2/1/08, 11:00 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
You might want to check into these tests too. They require a certification to use them and seem a lot more reliable and accurate than some of the testings swabs I have researched.
http://www.integritydetection.com/DrugWipe.html
Old 2/1/08, 11:14 PM
Check out this company if you want to go through the certification to use their tests in a commercial application.
http://www.global-detection.com/default.asp
Old 2/5/08, 10:39 PM
Agreed, it's a good test.
The way I look at it, I want to be able to look the client in the eye (and, especially a sue-happy RE agent!) and point to a LAB REPORT.
Let the lab take the credit / fall of a deal gone sour.
As I said, I use swabs to help me decide where to lab-test.
The Scott swabs are much cheaper as "sniffers".
Again, I can be emailed
Russ(at)cdaInspector.com for details regarding the lab I use. Dozens of fellow HIs have followed through with this offer. It's important to arm yourself with knowledge, and to protect your client. Once you've been "methed up" on an inspection (as Jeanne & I have), you'll understand why!
Mold , Meth & Monoxide -
I've been poisoned by them all on this job.
Old 2/27/08, 2:34 PM
FRHI's Avatar
FRHI FRHI is offline
Please Note: FRHI is a non-member guest and is in no way affiliated with InterNACHI or its members.
thanks for the info
Old 2/27/08, 3:33 PM
Greg Keene's Avatar
Greg Keene Greg Keene is online now
I do meth testing using the Meth-Chek 500 from SKC - that is the level for Colorado - kind of a big problem here in the mtns - cost is $35 a test but results on site in 5 minutes - this test kit was developed by the NOISH and CDC.
Want more info on meth go to www.drugfree.org/meth360. Really scary stuff -
Old 2/27/08, 9:10 PM
Greg, I've investigated those and, if I was an Industrial Hygenist (IH) instead of an HI, I'd be satisfied using them.
As is, I want a lab to take the credit -or fall- for the decision, so I have Mike Cooper provide me with lab results. Minimizes my responsibility!
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Inspection of HVAC by an area inspector. dmcauley Inspecting HVAC Systems 13 3/21/07 12:03 PM
Home Inspector Test Or Das Fazaland Home security test??? mlaverty Legislation, Licensing & Legal Issues for Inspectors 0 9/20/06 11:42 PM
